Server Stopping
  • insidesign
    • Dec 2018
    Server Stopping
    The server is running normal and it stops, with no apparent error, please see the image.
    I have already increased CacheSize in zabbix_server.conf but the problem continues.
    Can someone help me please?
  • andris
    Zabbix developer
    • Feb 2012
    • 228
    Something should have been happened before what is shown on the attached screenshot. Does server stop soon after start or after longer time ? What are earlier records n the zabbix_server.log ?
    • kloczek
      • Jun 2006
      • 1771
      Check zabbix server logs/
      • doctorbal82
        • Oct 2016
        • 39
        You can increase the zabbix server debug level to gather more information as to why it stopped.
        Here is a good blog post from the Zabbix Blog that still applies to any Zabbix 2.4+ version - https://blog.zabbix.com/zabbix-2-4-f...changing/3653/.
        Ensure when you do increase the log level (default is set to 3; and maximum set to 5) that you set it back to original unless you want your log files, which are hopefully rotated, to fill up too much disk space.
        zabbix_server --runtime-control log_level_increase
        Also I would suggest to review the database logs. You can increase the verbosity on there as well if you prefer depending on the database you use and configs.
        It appears from the screenshot there was a slow query at a particular point when updating either one of the tables.
