First Install SNMP help
  • TechforMarsh
    • Dec 2018
    Sorry, totally new to this.
    Installed successfully on a Ubuntu 18.04 headless server. Primary use will be to monitor a number of Juniper Switches. I added two and can not for life of me figure out how to get SNMP to work. After following the default install instructions and setup of server I found notes about the following:
    sudo apt install snmp
    sudo apt-get install snmp-mibs-downloader
    sudo download-mibs
    Ran all three and still no luck on the system. I ever rebooted the system and waited an hour just in case. The log file does not say anything about SNMP or missing MIBs at this point. Anyone have a sample page for setting up SNMP for a network switch on the latest version? Preferably an idiot proof doc that I can follow.
  • LenR
    • Sep 2009
    • 1011
    Try command line tools from the server (like snmpwalk) to see if you can access your devices.
