My zabbix proxy has a data sending delay problem
  • itwenjian
    • Dec 2018
    When my ZABBIX proxy VPS reached 4000, I found that the data sending process of ZABBIX proxy would be 100% all the time, and the data receiving process of zabbix-server would be delayed.
    This is my zabbix-proxy configuration file:
    AllowRoot=0
    CacheSize=8G
    ConfigFrequency=60
    DataSenderFrequency=60
    DBHost=localhost
    DBName=zabbix_proxy
    DBPassword=zabbix
    DBPort=10240
    DBSocket=/data/mysql/log/mysqld.sock
    DBUser=root
    DebugLevel=3
    EnableRemoteCommands=1
    Fping6Location=/usr/sbin/fping6
    FpingLocation=/usr/sbin/fping
    HeartbeatFrequency=60
    HistoryCacheSize=2G
    HistoryIndexCacheSize=2G
    Hostname=zabbix-proxy001
    HousekeepingFrequency=1
    JavaGateway=0.0.0.0
    JavaGatewayPort=10052
    ListenIP=0.0.0.0
    ListenPort=10051
    LogFile=/data/zabbix/zabbix_proxy.log
    LogFileSize=1024
    LogRemoteCommands=1
    LogSlowQueries=0
    LogType=file
    PidFile=/var/run/zabbix/zabbix_proxy.pid
    ProxyLocalBuffer=0
    ProxyMode=0
    ProxyOfflineBuffer=2
    ServerPort=10051
    Server=192.168.100.10
    SocketDir=/var/run/zabbix
    StartDBSyncers=32
    StartDiscoverers=16
    StartHTTPPollers=5
    StartIPMIPollers=10
    StartJavaPollers=16
    StartPingers=32
    StartPollers=32
    StartPollersUnreachable=32
    StartTrappers=24
    Timeout=30
    TLSAccept=unencrypted
    TLSConnect=unencrypted
    TmpDir=/tmp
    TrapperTimeout=300
    UnavailableDelay=60
    UnreachableDelay=60
    UnreachablePeriod=45
    User=zabbix
  • everaldocabral
    • Jan 2019
    • 9
    I have the same problem
    Informations Zabbix Proxy:
    zabbix-release-4.0-1.el7.noarch
    zabbix-agent-4.0.1-1.el7.x86_64
    zabbix-get-4.0.1-1.el7.x86_64
    zabbix-proxy-mysql-4.0.1-1.el7.x86_64
    • LenR
      • Sep 2009
      • 1011
      Always include the version of zabbix
      • everaldocabral
        • Jan 2019
        • 9
        Sorry! Edited.
        • nneka
          • Jun 2011
          • 9
          HI
          you should check your database performance and also the network bewteen the proxy and the server.
          to better understand your problem , you should share the monitoring graf (internal check - process and caches) of the proxies . Monitor this value proxy_history Regads
          • everaldocabral
            • Jan 2019
            • 9
            Originally posted by nneka
            HI
            Comunication is ok with the server.
            • everaldocabral
              • Jan 2019
              • 9
              Solved ==> https://support.zabbix.com/browse/ZB...DAxbbsJgWYEkLE
