Zabbix Login
  • orengo
    • Jul 2006
    Zabbix Login
    Please,
    My first login : admin and password : "blank" don´t works
    my release is 1.1.
    What happened ?
  • vrtareg
    • May 2006
    • 293
    Originally posted by orengo
    Please,
    my release is 1.1.
    What happened ?
    Hi
    "blank" password means that you have to type nothing in password field.
    Don't try to type "blank" word in it
    Regards
    Areg
    • orengo
      • Jul 2006
      Blank Password
      Ok. I don´t type any word, is blank screen, but zabbix don,t run. My php directory is /var/www/html/zabbix, because I
      use a FEDORA CORE 5.
      • vrtareg
        • May 2006
        • 293
        Hi
        Do ya correct set up database parameters in include/db.inc.php file?
        Please check it.
        Is this is fresh install or you upgrate from previous version?
        If this is fresh install do you import create/data/data.sql file into database?
        Regards
        Areg
        • just2blue4u
          • Apr 2006
          • 347
          If it's a new installation of zabbix server, just drop the whole DB.
          Then re-create it and install the *.sql from Zabbix Install.
          This worked for me when i had the same error.
          Big ZABBIX is watching you!
          (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
          • orengo
            • Jul 2006
            Login
            OK. Thank you. This works.
            Thanks a lot.
            orengo
