Zabbix Trigger overview - not showing OK triggers
  • a.ratnikov
    • Dec 2018
    • 13
    Hello!
    I made a screen and placed a trigger overview resource on it. And right now I don't see a green (OK) triggers, only problems. Before the Zabbix update 4.0.3 it worked well.
    Monitoring - Screens - My Screen before Zabbix update 4.0.3 there were also green cells. Right now they disappeared and only "No data Found" labeling.
    Is possible to make it shown back?
  • fmazzoli
    • Oct 2018
    Hello
    I have exactly the same problem with upgrade 4.0.3
    Workaround : downgrade zabbix-frontend-php to 4.0.2
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Please report this as a bug in https://support.zabbix.com so that it gets fixed.
