JMX-related issue. From time to time lost connection to JMX interfaces
  • sirmax123
    • Dec 2018
    Hi!
    I have an issue: from time to time Java Gateway is not able to get data from Cassandra nodes. (it _may be_ related to CPU load on monitored nodes but I can't find any correlations)
    For debugging I started Java Gateway in the following way, in screen on EC2 instance:
    ZABBIX_VERSION="4.0.3"
    JMX_PORT=10999
    cd /usr/share/zabbix-java-gateway
    java \
    -server \
    -Xms1024m \
    -Xmx2048m \
    -Dlogback.configurationFile=/etc/zabbix/zabbix_java_gateway_logback.xml \
    -classpath lib:lib/android-json-4.3_r3.1.jar:lib/logback-classic-0.9.27.jar:lib/logback-core-0.9.27.jar:lib/slf4j-api-1.6.1.jar:bin/zabbix-java-gateway-${ZABBIX_VERSION}.jar \
    -Dzabbix.pidFile=/var/run/zabbix/zabbix_java_gateway.pid \
    -Dzabbix.listenIP=0.0.0.0 \
    -Dzabbix.listenPort=10052 \
    -Dzabbix.startPollers=10 \
    -Dzabbix.timeout=30 \
    -Djava.rmi.server.hostname="$(curl http://169.254.169.254/latest/meta-data/public-hostname 2>/dev/null)" \
    -Dcom.sun.management.jmxremote.rmi.port=${JMX_PORT} \
    -Dcom.sun.management.jmxremote.port=${JMX_PORT} \
    -Dcom.sun.management.jmxremote.authenticate="false" \
    -Dcom.sun.management.jmxremote="true" \
    -Dcom.sun.management.jmxremote.ssl="false" \
    -Djava.net.preferIPv4Stack=true \
    -Dcom.sun.management.jmxremote.local.only="false" \
    -Dsun.rmi.transport.tcp.responseTimeout=100000 \
    com.zabbix.gateway.JavaGateway
    Java gateway also configured to be JMX-enabled and I do not see any gaps in charts, but see gaps in other JMX-monitored nodes
    In logs I see
    2018-12-24 11:01:52.711 [pool-1-thread-2] WARN com.zabbix.gateway.SocketProcessor - error processing request: Broken pipe (Write failed)
    2018-12-24 11:01:52.711 [pool-1-thread-2] WARN com.zabbix.gateway.SocketProcessor - error sending failure notification: Broken pipe (Write failed)
    2018-12-24 11:01:53.542 [pool-1-thread-7] WARN com.zabbix.gateway.SocketProcessor - error processing request: Broken pipe (Write failed)
    2018-12-24 11:01:53.542 [pool-1-thread-7] WARN com.zabbix.gateway.SocketProcessor - error sending failure notification: Broken pipe (Write failed)
    2018-12-24 11:01:54.541 [pool-1-thread-5] WARN com.zabbix.gateway.SocketProcessor - error processing request: Broken pipe (Write failed)
    2018-12-24 11:01:54.541 [pool-1-thread-5] WARN com.zabbix.gateway.SocketProcessor - error sending failure notification: Broken pipe (Write failed)
    2018-12-24 11:02:25.239 [pool-1-thread-10] WARN com.zabbix.gateway.SocketProcessor - error processing request: Broken pipe (Write failed)
    JMX-nodes are Cassandra, and I have configured Autodiscovery:
    Key: jmx.discovery[attributes, "org.apache.cassandra.metrics:type=Table,keyspace= *,scope=*,name=ReadLatency"]
    It returns ~300 items because I have many tablespaces.
    So my questions are:
    - What is recommended JVM settings for Java Gateway if I need to monitor ~10 000 items or more?
    - What is recommended settings for
    -Dzabbix.startPollers ?
    -Dzabbix.timeout ?
    - How many pollers is recommended to set in zabbix_server.conf
    I have
    StartJavaPollers=100
    Any suggestions will be appreciated!
    Best Regards,
    Max
  • sirmax123
    • Dec 2018
    Originally posted by alamin
    Find out your solution goto below link
    Check all config for monitor Tomcat via Zabbix JMX interface
    Thanks.
    Web : https://technologyrss.com
    YouTube
    Thank you for your reply, but I'm so sorry, are you kidding me???
    1. Your post is just link to the simple JMX monitoring configuration (as simple as it is possible with JMX at all)
    2. There is nothing about JVM configuration for Java Gateway.
    3. I already configured JMX (if you check my post you''ll be see the issue is that data is lost from time to time)
    (answer is looking like created by robot which see "JMX" keyword and just posted pre-defined reply)
    • rodrigomartins
      • Jan 2019
      sirmax123 - have you managed to workaround this issue? I'm having the exactly same problem, it works fine for 12-13 hours and then it fails, it only works after restarting zabbix_java. The interesting is part here is that I've got another Zabbix instance with pretty much the same configuration and working fine there.
