SNMP Traps
  • lmontalvanr
    • Feb 2016
    • 21
    SNMP Traps
    Hi everyone.
    What' recommend by snmp traps collect:
    - Zabbix_traps_receiver.pl
    - SNMPTT.
    - SNMPTTHANDLER.
    I have Centos 7 on zabbix 4.0.2.
    My Traps configuration is the following:
    /etc/snmp/snmptrapd.conf
    traphandle default /usr/sbin/snmptthandler
    disableAuthorization yes
    authCommunity log,execute,net public
    /etc/sysconfig/snmptrapd
    OPTIONS="-m +ALL -Ls6 -On -p /var/run/snmptrapd.pid"
    /etc/snmp/snmptt.ini
    [General]
    snmptt_system_name = zabbix_server
    mode = standalone
    multiple_event = 1
    dns_enable = 0
    strip_domain = 0
    resolve_value_ip_addresses = 0
    net_snmp_perl_enable = 1
    net_snmp_perl_cache_enable = 1
    net_snmp_perl_best_guess = 0
    translate_log_trap_oid = 2
    translate_value_oids = 2
    translate_enterprise_oid_format = 1
    translate_trap_oid_format = 1
    translate_varname_oid_format = 1
    translate_integers = 1
    #mibs_environment = ALL
    wildcard_expansion_separator = " "
    allow_unsafe_regex = 1
    remove_backslash_from_quotes = 0
    dynamic_nodes = 0
    description_mode = 2
    description_clean = 1
    threads_enable = 0
    threads_max = 10
    date_time_format = %Y/%m/%d %Y %H:%M:%S
    [DaemonMode]
    daemon_fork = 1
    daemon_uid = snmptt
    pid_file = /var/run/snmptt.pid
    spool_directory = /var/spool/snmptt/
    sleep = 5
    use_trap_time = 1
    keep_unlogged_traps = 1
    duplicate_trap_window = 0
    [Logging]
    stdout_enable = 0
    log_enable = 1
    log_file = /tmp/zabbix_traps.log
    log_system_enable = 1
    log_system_file = /var/log/snmptt/snmpttsystem.log
    unknown_trap_log_enable = 1
    unknown_trap_log_file = /var/log/snmptt/unknown_traps.log
    statistics_interval = 0
    syslog_enable = 1
    syslog_facility = local0
    syslog_level = warning
    syslog_system_enable = 1
    syslog_system_facility = local0
    syslog_system_level = warning
    [Exec]
    exec_enable = 1
    pre_exec_enable = 1
    unknown_trap_exec =
    unknown_trap_exec_format = $aR [unknown] [unknown] $+*
    exec_escape = 1
    [Debugging]
    DEBUGGING = 2
    DEBUGGING_FILE = /var/log/snmptt/snmptt.debug
    DEBUGGING_FILE_HANDLER = /var/log/snmptt/snmptthandler.debug
    /etc/snmptt/snmptt.conf
    EVENT linkDown .1.3.6.1.6.3.1.1.5.3 "Status Events" Normal
    FORMAT ZBXTRAP Link down on interface $1. Admin state: $2. Operational state: $3
    EXEC qpage -f TRAP notifygroup1 "Link down on interface $1. Admin state: $2. Operational state: $3"
    EVENT linkUp .1.3.6.1.6.3.1.1.5.4 "Status Events" Normal
    FORMAT ZBXTRAP Link up on interface $1. Admin state: $2. Operational state: $3
    EXEC qpage -f TRAP notifygroup1 "Link up on interface $1. Admin state: $2. Operational state: $3"
    EVENT general .* "General event" Normal
    FORMAT ZBXTRAP $aA $+*
    In the /tmp/zabbix_traps.log file it shows the following:
    2018/12/26 2018 09:51:11 IF-MIB::linkUp Normal "Status Events" 172.16.13.249 - ZBXTRAP Link up on interface 14.  Admin state: up.  Operational state: up
    2018/12/26 2018 09:51:11 SNMPv2-SMI::enterprises.11.2.3.7.11.181.4.0.2 Normal "General event" 172.16.13.249 - ZBXTRAP 172.16.13.249 eventDescription.76:I 12/26/18 08:51:09 00076 ports: port 14 is now on-line
    On zabbix GUI only show
    I want know Why don“t show on yhe zabbix console:
    In the snmptt.debug show:
    Processing file: #snmptt-trap-1545839307549608
    Reading trap.  Current time: Wed Dec 26 10:48:31 2018
    Raw trap passed from snmptrapd:
    1545839307
    <UNKNOWN>
    UDP: [172.16.13.249]:161->[172.16.0.224]:162
    .1.3.6.1.2.1.1.3.0 97:18:42:19.52
    .1.3.6.1.6.3.1.1.4.1.0 .1.3.6.1.4.1.11.2.3.7.11.181.4.0.2
    .1.3.6.1.2.1.16.9.1.1.2.76 I 12/26/18 09:48:24 00076 ports: port 14 is now on-line
    .1.3.6.1.6.3.18.1.3.0 172.16.13.249
    .1.3.6.1.6.3.18.1.4.0 "public"
    .1.3.6.1.6.3.1.1.4.3.0 .1.3.6.1.4.1.11.2.3.7.11.181.4
    Items passed from snmptrapd:
    value 0: 172.16.13.249
    value 1: 172.16.13.249
    value 2: .1.3.6.1.2.1.1.3.0
    value 3: 97:18:42:19.52
    value 4: .1.3.6.1.6.3.1.1.4.1.0
    value 5: .1.3.6.1.4.1.11.2.3.7.11.181.4.0.2
    value 6: .1.3.6.1.2.1.16.9.1.1.2.76
    value 7: I 12/26/18 09:48:24 00076 ports: port 14 is now on-line
    value 8: .1.3.6.1.6.3.18.1.3.0
    value 9: 172.16.13.249
    value 10: .1.3.6.1.6.3.18.1.4.0
    value 11: public
    value 12: .1.3.6.1.6.3.1.1.4.3.0
    value 13: .1.3.6.1.4.1.11.2.3.7.11.181.4
    Agent IP address (172.16.13.249) is the same as the host IP, so copying the host name: 172.16.13.249
    Trap received from 172.16.13.249: .1.3.6.1.4.1.11.2.3.7.11.181.4.0.2
    0:        hostname
    1:        ip address
    2:        uptime
    3:        trapname / OID
    4:        ip address from trap agent
    5:        trap community string
    6:        enterprise
    7:        securityEngineID        (snmptthandler-embedded required)
    8:        securityName            (snmptthandler-embedded required)
    9:        contextEngineID         (snmptthandler-embedded required)
    10:        contextName             (snmptthandler-embedded required)
    0+:        passed variables
    Value 0: 172.16.13.249
    Value 1: 172.16.13.249
    Value 2: 97:18:42:19.52
    Value 3: .1.3.6.1.4.1.11.2.3.7.11.181.4.0.2
    Value 4: 172.16.13.249
    Value 5: public
    Value 6: .1.3.6.1.4.1.11.2.3.7.11.181.4
    Value 7:
    Value 8:
    Value 9:
    Value 10:
    Agent dns name: 172.16.13.249
    Ent Value 0 ($1): .1.3.6.1.2.1.16.9.1.1.2.76=I 12/26/18 09:48:24 00076 ports: port 14 is now on-line
    Exact match of trap NOT found in EVENT hash table
    Looking for wildcards in the EVENT hash table
    Drilling down looking for wildcards in the EVENT hash table
    .1.3.6.1.4.1.11.2.3.7.11.181.4.0.*
    .1.3.6.1.4.1.11.2.3.7.11.181.4.*
    .1.3.6.1.4.1.11.2.3.7.11.181.*
    .1.3.6.1.4.1.11.2.3.7.11.*
    .1.3.6.1.4.1.11.2.3.7.*
    .1.3.6.1.4.1.11.2.3.*
    .1.3.6.1.4.1.11.2.*
    .1.3.6.1.4.1.11.*
    .1.3.6.1.4.1.*
    .1.3.6.1.4.*
    .1.3.6.1.*
    .1.3.6.*
    .1.3.*
    .1.*
    Trap not defined...
    I hope you can help me.
