Can't found zabbix_sender
  • ITIC007
    • Oct 2018
    • 19
    I installed the agent package on a Linux machine but I can't find the zabbix_sender utility:
    -bash: /usr/bin/zabbix_sender: No such file or directory
    Does the agent and the zabbix_sender comes in separate? If so, how can I install the zabbix_sender?
  • Atsushi
    • Aug 2013
    • 2028
    What OS are you using?
    Depending on the repository you are using, if you are using a Zabbix official repository, the zabbix_sender command should be in a separate package from the Zabbix agent.
    If you are using RHEL or CentOS and you are registering a Zabbix official yum repository, you can install it using the following command.
    # yum install zabbix-sender
    If you are using Debian or Ubuntu and you are registering an official Zabbix repository, you can install it with the following command.
    # apt install zabbix-sender
