SNMP Value seams to be duplicate
  • johannesraff
    • Nov 2017
    I have three values, I want to check with Zabbix. I have create simple SNMPv2 checks for the full length of the OIDs, mentioned in the snmpwalk. If I create the first check, all works fine and values come back. As soon as I create the second value, either the first or second check fail with the error: became not supported: No Such Instance currently exists at this OID
    Those are created in a template, but as they are singe checks, I dont see the issue. What am I doing wrong?
    snmpwalk -c 'mysecret' -v 2c hostname 1.3.6.1.4.1.10704.1.10.1.1.8.102.119.83.116.97.116 .115.0
    SNMPv2-SMI::enterprises.10704.1.10.1.1.8.102.119.83.116.9 7.116.115.0 = INTEGER: 18
    snmpwalk -c 'mysecret' -v 2c hostname 1.3.6.1.4.1.10704.1.10.1.2.8.102.119.83.116.97.116 .115.0
    SNMPv2-SMI::enterprises.10704.1.10.1.2.8.102.119.83.116.9 7.116.115.0 = INTEGER: 27
    snmpwalk -c 'mysecret' -v 2c hostname 1.3.6.1.4.1.10704.1.10.1.3.8.102.119.83.116.97.116 .115.0
    SNMPv2-SMI::enterprises.10704.1.10.1.3.8.102.119.83.116.9 7.116.115.0 = INTEGER: 9200
    I am running Zabbix 4.0.3 but I don't think my issue has to do with the version
    Many thanks for your help.
  • finalbeta
    • Sep 2015
    • 9
    Please try with "Disable bulk requests" on the SNMP interface of the host.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      If you have Use bulk requests enabled in the SNMP interface, see if disabling it helps.
