Zabbix Server drops after hosts enabled and then wont start anymore
  • ManthysBR
    • Jul 2018
    Hi, first of all sorry for the bad english, is not my mother tongue.
    So, i'm setting up a zabbix server 4.0 hosted on a Google Cloud Server. It works pretty good until i enable my most important hosts ( switch stacks, monitoring just the aggregation ports and cpu, memory and hardware stuff ).
    When i enable three or more hosts, my zabbix-server service drops, and never starts again. If i get the status for the service, it shows me this:
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) (Result: exit-code) since Sun 2018-12-30 16:03:01 UTC; 5s ago
    Process: 30915 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
    Process: 30911 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 30913 (code=exited, status=1/FAILURE)
    Dec 30 16:03:01 zabbixnew systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    Dec 30 16:03:01 zabbixnew systemd[1]: zabbix-server.service: Unit entered failed state.
    Dec 30 16:03:01 zabbixnew systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    When i go to ''Queue'' it shows me
    Details Cannot display item queue.
    • Connection to Zabbix server "localhost" refused. Possible reasons:
    • 1. Incorrect server IP/DNS in the "zabbix.conf.php";
    • 2. Security environment (for example, SELinux) is blocking the connection;
    • 3. Zabbix server daemon not running;
    • 4. Firewall is blocking TCP connection.
    • Connection refused
    SELinux is disabled, since i got this problem before and disabled all hosts and it suddenly get back to work.
    The data on the conf files are ok because i didnt change anything on them, just enabled the hosts for monitoring.
    I think there is some problem on the server config file, on the tunning, but i cant find a solution for this.
    Can you guys enlighten me?
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Please provide log file
