Maintenance status does not show in drop-down for Action
  • mrkafk
    • Dec 2018
    I am using Zabbix 4.0.2 Postgres version.
    This problem is similar to https://www.zabbix.com/forum/zabbix-...sending-alerts .
    I would like to define "Maintenance status not in maintenance" for the trigger in default notification ("Report problems to Zabbix administrators"); however, "Maintenance status" is not shown as one of the possible values:
    Sorry for blurry drop down, that's all I could do with screenshot.
    I may be able to get around this in practice by using this "Time period" corresponding to maintenance window defined, but I would rather have proper solution to this problem.
  • aigars.kadikis
    • Mar 2018
    • 208
    On 3.4 this option calls "Maintenance status"
    On 4.0 this option is called "Problem is suppressed"
