Dockerize Zabbix Server
  • You Chee Yong
    • Jan 2019
    Hi
    I have a Zabbix Server VM running into a Centos 7 OS.
    I would dokerize this server without lost any data or templeate
    How i can dockerize Zabbix ?
    Thank You
  • zux
    • Sep 2018
    • 97
    I believe you should be able to just run docker version of zabbix (just give it the same config file options in parameters) and then transfer the existing DB. Or Of you do not plan to put the DB in docker, you can just point the dockerized Zabbix to the existing DB. (Just make sure you shut down the old server before that)
