Problem with linux zabbix agent after server upgrade to 4.0.3
  • novazion
    • Sep 2013
    • 13
    I've I thought successfully upgrade my zabbix server from 2.2 to 3.4 then 4.0.3.
    On server side everything seems fine.
    But on Linux agents side i've got those error message:
    28483:20190107:212335.061 no active checks on server [***********:10051]: "" is not a valid IP address
    I tried to update the agent to 4.0 but no luck.
    Thanks for your help!
    Emeric.
  • LenR
    • Sep 2009
    • 1011
    What do you have for ServerActive in the config file? I know you sanitized it, but it reads like the ********** part isn't a valid ip. Try removing the :10051 since that is the default port.
    • vso
      Zabbix developer
      • Aug 2016
      • 190
      Is there any value for ListenIP in agent configuration file ?
      • novazion
        • Sep 2013
        • 13
        Sorry for the delay.
        Thanks vso. Thje problem was there. No Ip in ListenIP parameter.
        I Disable passive check. Only Active so before(2.x) there was no need I think of Listen IP Parameter.
