Items from Template get not updated
  • xundeenergie
    • Jan 2019
    Hi there!
    I have a template with some discovery rules and prototyped items and triggers.
    Now i added an additional protoype-item, but on the hosts, where the template is linked, the new items get not created. Also the trigger from the prototype are not created.
    I unlinked the template, and linked it again... no new items or triggers.
    Then i saw, that the existing items from the template have not template-name in front of the item-name...
    Accidentally i unlinked and cleared the Template from the host... and all items and triggers are removed after that.
    So i linked the template again... NO items or triggers are created...
    There is a zabbix-proxy between the monitoring-instance and the monitored host. Maybe this is the problem?
    Thanks for advice
    jakob
  • zux
    • Sep 2018
    • 95
    Give it some time. proxy doesn't get configuration updates instantly. You also need to wait for the discovery rule to run, after you create the new item prototypes.
