Zabbix Migration from 2.2.8 to 4.0
  • sahansam
    • Jan 2019
    Hi Everyone,
    I have already installed Zabbix Server v2.2.8 Need to upgrade it to v4.0 ,
    I was going through the Upgrade manual -> https://www.zabbix.com/documentation...es/rhel_centos
    but Ended up with the below error when ran the command -> yum upgrade zabbix-server-mysql zabbix-web-mysql zabbix-agent
    Please Refer below to the Error , i think some dependencies are missing here , There are Errors at the bottom, how to successfully migrate it to the newer version please Help !!!
    [root@zabbix ~]# yum upgrade zabbix-server-mysql zabbix-web-mysql zabbix-agent
    Loaded plugins: fastestmirror, security
    Setting up Upgrade Process
    Loading mirror speeds from cached hostfile
    * base: repos.forethought.net
    * extras: repos.forethought.net
    * updates: repos.forethought.net
    Resolving Dependencies
    --> Running transaction check
    ---> Package zabbix.x86_64 0:2.2.8-1.el6 will be obsoleted
    ---> Package zabbix-agent.x86_64 0:2.2.8-1.el6 will be updated
    ---> Package zabbix-agent.x86_64 0:4.0.3-1.el7 will be obsoleting
    --> Processing Dependency: libc.so.6(GLIBC_2.17)(64bit) for package: zabbix-agent-4.0.3-1.el7.x86_64
    --> Processing Dependency: systemd for package: zabbix-agent-4.0.3-1.el7.x86_64
    --> Processing Dependency: libpcre.so.1()(64bit) for package: zabbix-agent-4.0.3-1.el7.x86_64
    ---> Package zabbix-server.x86_64 0:2.2.8-1.el6 will be obsoleted
    ---> Package zabbix-server-mysql.x86_64 0:2.2.8-1.el6 will be updated
    ---> Package zabbix-server-mysql.x86_64 0:4.0.3-1.el7 will be obsoleting
    --> Processing Dependency: libc.so.6(GLIBC_2.17)(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: libmysqlclient.so.18(libmysqlclient_18)(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: systemd for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: libmysqlclient.so.18()(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: libnetsnmp.so.31()(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: libpcre.so.1()(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    --> Processing Dependency: libevent-2.0.so.5()(64bit) for package: zabbix-server-mysql-4.0.3-1.el7.x86_64
    ---> Package zabbix-web-mysql.noarch 0:2.2.8-1.el6 will be updated
    --> Processing Dependency: zabbix-web-database = 2.2.8-1.el6 for package: zabbix-web-2.2.8-1.el6.noarch
    ---> Package zabbix-web-mysql.noarch 0:4.0.3-1.el7 will be an update
    ---> Package libevent2.x86_64 0:2.0.21-2.el6 will be installed
    ---> Package zabbix-web.noarch 0:2.2.8-1.el6 will be updated
    ---> Package zabbix-web.noarch 0:4.0.3-1.el7 will be an update
    --> Processing Dependency: php >= 5.4 for package: zabbix-web-4.0.3-1.el7.noarch
    --> Processing Dependency: php-ldap for package: zabbix-web-4.0.3-1.el7.noarch
    ---> Package php-ldap.x86_64 0:5.3.3-49.el6 will be installed
    --> Finished Dependency Resolution
    Error: Package: zabbix-agent-4.0.3-1.el7.x86_64 (zabbix)
    Requires: systemd
    Error: Package: zabbix-web-4.0.3-1.el7.noarch (zabbix)
    Requires: php >= 5.4
    Installed: php-5.3.3-49.el6.x86_64 (@pearson-monthly)
    php = 5.3.3-49.el6
    Error: Package: zabbix-server-mysql-4.0.3-1.el7.x86_64 (zabbix)
    Requires: libc.so.6(GLIBC_2.17)(64bit)
    Requires: libpcre.so.1()(64bit)
    Requires: systemd
    Requires: libnetsnmp.so.31()(64bit)
    Requires: libmysqlclient.so.18(libmysqlclient_18)(64bit)
    Requires: libmysqlclient.so.18()(64bit)
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    [root@zabbix ~]#
  • zux
    • Sep 2018
    • 95
    did you install the correct release package for your version of OS?
    What is the OS and version? What's in /etc/yum.repos.d/zabbix.repo?
    • Atsushi
      • Aug 2013
      • 2028
      Package for RHEL 7(CentOS 7) can not be used for RHEL 6(CentOS 6).
      Also note that in RHEL 6, it is necessary to upgrade PHP to version 5.4 or later versions other than OS standard.
      • sahansam
        • Jan 2019
        My OS is -> CentOS release 6.5 (Final) i think the Repository supports only for CentOS 7.
        How do i upgrade from 2.2.8 to 4.0 Zabbix
        Please Advice me and help !
        • Atsushi
          Atsushi commented
          The repository for RHEL 6 (CentOS 6) is located at the following URL.
          However, since the version is old with RHEL 6 standard PHP, it is necessary to migrate to PHP environment PHP 5.4 or lator. Because it can not cope with the OS standard repository, it is possible to migrate to a new OS or use a repository such as remi.
      • zux
        • Sep 2018
        • 95
        Please look carefully, there are repositories for CentOS 6 go to download site and select your version. You will probably have to remove the existing incorrect repository and add the version for CentOS6
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          You can install zabbix 4.0 repository configuration by executing the following command:
          sudo rpm -Uvh https://repo.zabbix.com/zabbix/4.0/rhel/7/x86_64/zabbix-release-4.0-1.el7.noarch.rpm
          After that you can upgrade Zabbix packages along with system upgrade by executing:
          sudo yum update
          For the future, download instructions are always available here:
          Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
          • Atsushi
            Atsushi commented
            sahansam seems to be using CentOS 6.5. It is not appropriate to introduce a repository for RHEL 7.
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          Ah, thanks, Atsushi.
          sahansam, I'd recommend you the following:
