Hi all,
I have installed a single Zabbix 3.0 LTS server on Azure. I have enabled the web front end on the Zabbix server itself and I have also configured a 2nd VM with only the front end.
Following some interesting tussles with SELinux and Azure network security I have now got both front end's working. BUT........
When I access the Zabix front end via the Zabbix Server itself, the initial dashboard tells me that the Zabbix server is running. However, when I access the Zabbix server via the 2nd front end VM the initial dashboard says that the Zabbix server is NOT running. Further, even though the 2nd VM says that the Zabbix server is NOT running I am able to successfully create hosts (just a simple task) via the 2nd front end.
In summary, the Zabbix status dashboard is saying a different thing when accessed from different web front ends.
I hope this is clear
Has anyone else had this issue or offer me some advice on how to address it.
All advice is gratefully received.
Regards,
Dave
Regards,
Dave
