Errors in Zabbix 4.0 Dashboard
  • david_harrison
    • Jan 2019
    /Hi,
    Just starting to evaluate Zabbix for my home Lab.
    I did a fresh appliance install of Zabbix 4, have been testing out agents on Linux an Windows x64 with general success.
    Yesterday I tried the vCenter integration, and was able to get the discovery working well ( although I would like to see how you can batch rename the discovered hosts so the UI looks cleaner ).
    I did need to update some server config around, pollers, cahce sizes etc as when I enabled the VMWare pollers, the server would suddenly stop after a few minutes of operation. This issue has now gone away.
    But, since making those changes, I am getting some PHP errors presenting in one of the stardard dashboard portlets, "Problem by Severity"
    • Undefined variable: problems_data [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidgetProblemsBySvView->doAction() → getSystemStatusData() in include/blocks.inc.php:281]
    • Invalid argument supplied for foreach() [zabbix.php:21 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidgetProblemsBySvView->doAction() → getSystemStatusData() → CScreenProblem::makeData() in include/classes/screens/CScreenProblem.php:562]
    not sure why this has started to happen??
    Log file ( ignore messages from agents I was using for testing that don;t have host profiles ), and server config attached.
    thanks
    David
  • LenR
    • Sep 2009
    • 1011
    bug, should be fixed in 4.0.4. hits non super admins if show suppressed is checked.
    (injured, only left hand typing,sorry)
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      I think it's this one https://support.zabbix.com/browse/ZBX-15373
