I have the following configuration:
Zabbix Server (behind nat, external IP 1.1.1.1, private IP 192.168.0.1
Zabbix Proxy (behind nat, external IP 2.2.2.2, private IP 10.0.0.1)
Zabbix Agent (behind nat, external IP 2.2.2.2, private IP 10.0.0.1) - the agent is installed on the same machine as the proxy - for testing purposes only.
Please note that proxy and agent are on a different private network than zabbix server.
I would like to monitor the Zabbix Agent host, through the Zabbix Proxy, for active and passive checks.
I have defined the Proxy as Zabbix Proxy (with mode Active and IP 2.2.2.2).
I have defined a host Zabbix Agent, which I set on the interface 2.2.2.2 and port 10050.
The proxy is Online, but the Agent says:
Get value from agent failed: cannot connect to [[2.2.2.2]:10050]: [4] Interrupted system call
In the agent config I have set:
Server=127.0.0.1,2.2.2.2,1.1.1.1
ServerActive=127.0.0.1,2.2.2.2
Need to mention that the ports 10050 and 10051 are opened from proxy / agent to and from the zabbix server (any telnet to the public IP's will work, no matter in which dirrection).
The thing is the only flow that doesn't work is telnet on ports 10050 and 10051 FROM the proxy/agent itself, because it needs to go through the router, and I know I would simply add a DNAT rule to make it work, but I do not want all the traffic from my local network (maybe more than 100 servers with agents installed) to go through the router while they are on the same private network with the proxy.
Could someone point me in the right direction please ?
Thanks,
Daniel
Thanks,
Daniel
