Hi all,
Logging into my zabbix I'm getting 'Zabbix server is not running:the information displayed may not be current'
Checking the status showes it running but the
systemctl status zabbix-server
lines 1--1...skipping...
● zabbix-server.service - Zabbix Server
Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2019-01-25 13:23:33 UTC; 171ms ago
Process: 9479 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
Main PID: 9490 (zabbix_server)
Tasks: 1 (limit: 9472)
CGroup: /system.slice/zabbix-server.service
└─9490 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
Jan 25 13:23:33 zabbix systemd[1]: Starting Zabbix Server...
Jan 25 13:23:33 zabbix systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
Jan 25 13:23:33 zabbix systemd[1]: Started Zabbix Server.
Jan 25 13:23:33 zabbix systemd[1]: zabbix-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 25 13:23:33 zabbix systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
Checking /var/log/zabbix/zabbix_server.log its showing
x
10249:20190125:132735.106 === Backtrace: ===
10249:20190125:132735.106 9: /usr/sbin/zabbix_server(zbx_backtrace+0x44) [0x55c220deace4]
10249:20190125:132735.106 8: /usr/sbin/zabbix_server(__zbx_mem_realloc+0x14d) [0x55c220de6dee]
10249:20190125:132735.106 7: /usr/sbin/zabbix_server(+0xc5248) [0x55c220db1248]
10249:20190125:132735.106 6: /usr/sbin/zabbix_server(+0xd0883) [0x55c220dbc883]
10249:20190125:132735.106 5: /usr/sbin/zabbix_server(DCsync_configuration+0x1136) [0x55c220dbdc2d]
10249:20190125:132735.106 4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x6b7) [0x55c220d24179]
10249:20190125:132735.106 3: /usr/sbin/zabbix_server(daemon_start+0x315) [0x55c220dea42d]
10249:20190125:132735.106 2: /usr/sbin/zabbix_server(main+0x305) [0x55c220d23aac]
10249:20190125:132735.106 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fa23d170b97]
10249:20190125:132735.106 0: /usr/sbin/zabbix_server(_start+0x2a) [0x55c220d22c7a]
10282:20190125:132745.316 Starting Zabbix Server. Zabbix 4.0.1 (revision 86073).
10282:20190125:132745.316 ****** Enabled features ******
10282:20190125:132745.316 SNMP monitoring: YES
10282:20190125:132745.316 IPMI monitoring: YES
10282:20190125:132745.316 Web monitoring: YES
10282:20190125:132745.316 VMware monitoring: YES
10282:20190125:132745.316 SMTP authentication: YES
10282:20190125:132745.316 Jabber notifications: YES
10282:20190125:132745.316 Ez Texting notifications: YES
10282:20190125:132745.316 ODBC: YES
10282:20190125:132745.316 SSH2 support: YES
10282:20190125:132745.316 IPv6 support: YES
10282:20190125:132745.316 TLS support: YES
10282:20190125:132745.316 ******************************
10282:20190125:132745.316 using configuration file: /etc/zabbix/zabbix_server.conf
10282:20190125:132745.319 current database version (mandatory/optional): 04000000/04000000
10282:20190125:132745.319 required mandatory version: 04000000
10282:20190125:132745.561 __mem_malloc: skipped 0 asked 24 skip_min 18446744073709551615 skip_max 0
10282:20190125:132745.561 [file:dbconfig.c,line:94] zbx_mem_realloc(): out of memory (requested 16 bytes)
10282:20190125:132745.561 [file:dbconfig.c,line:94] zbx_mem_realloc(): please increase CacheSize configuration parameter
10282:20190125:132745.561 === memory statistics for configuration cache ===
10282:20190125:132745.561 min chunk size: 18446744073709551615 bytes
10282:20190125:132745.561 max chunk size: 0 bytes
10282:20190125:132745.561 memory of total size 8388232 bytes fragmented into 75484 chunks
10282:20190125:132745.561 of those, 0 bytes are in 0 free chunks
10282:20190125:132745.561 of those, 7180504 bytes are in 75484 used chunks
10282:20190125:132745.561 ================================
Just to rule it out I've check the zabbix.conf.php conf settings and there appear to be correct:
// Zabbix GUI configuration file.
global $DB;
$DB['TYPE'] = 'MYSQL';
$DB['SERVER'] = 'localhost';
$DB['PORT'] = '0';
$DB['DATABASE'] = 'zabbix';
$DB['USER'] = 'zabbix';
$DB['PASSWORD'] = 'MYPASSWORD*';
// Schema name. Used for IBM DB2 and PostgreSQL.
$DB['SCHEMA'] = '';
$ZBX_SERVER = 'MYSERVERSIP';
$ZBX_SERVER_PORT = '10051';
$ZBX_SERVER_NAME = 'zabbix';
$IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
This only thing that has changed on the server is I have added around 100 new devices to monitor and then the error started appearing. I did notices that the ram was maxing out, so gave the vm more 8.
Not sure what the problem is?
x
global $DB;
$DB['PORT'] = '0';
$DB['SCHEMA'] = '';
