Zabbix 4.03 Trapper History and Trend Period totaly ignored!
  • P81282
    • Jan 2019
    • 10
    in the current version 4.03 of zabbix server I send the state from a backup script with the zabbix_sender.exe from windows clients, which works like expected, but after two days the data are gone in zabbix?!
    Here are the Template item configuration:
    and here are the Item settings from a host:
    How can I setup zabbix to store the history and trend data the timeperiod I set up?
    Many thank's in advance!
    Peter
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Please provide screenshot of housekeeping page in frontend.
    • P81282
      • Jan 2019
      • 10
      Hello VSO,
      many thank's for your reply!
      • vso
        Zabbix developer
        • Aug 2016
        • 190
        Are you using partitioning ?
        • P81282
          • Jan 2019
          • 10
          Hello VSO,
          what Partitioning means?
          Join the friendly and open Zabbix community on our forums and social media platforms.
          Is it for split table data into multiple files? --> No I don't use this until now.
          I use:
          zabbix-server-mysql 1:4.0.3-1+stretch amd64
          mariadb-server-10.1 10.1.37-0+deb9u1
          With InnoDB and one file per table enabled and
          62G /var/lib/mysql/zabbix/
          on:
          cat /etc/debian_version
          9.7
          Many thank's in advance for your support!
          • P81282
            • Jan 2019
            • 10
            today I investigate deeper into this issue and it apears that the data send by the trapper still here but the graphs do not show them!
            A item value "0" was send on January 23th and when I open the graph from the last 8 days it is shown:
            When I reduce the timespan to 7 days its gone:
            Even when I see the latest Data its shown like:
            The really "ugly" thing even when I access the item data with the zabbix-api there is no lastvalue and lastclock returned so I don't know if the backup was done or when or with wich result!
            Many thank's for your support in advance!
            • P81282
              • Jan 2019
              • 10
              The issue is solved now! https://www.zabbix.com/forum/zabbix-...268#post373268
