Hi, we have updated zabbix server to 4.0.4 version and now when is running its stop, generating the next log:
3983:20190205:142636.937 item "host1:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host2:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host3:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host4:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host5:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host6:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host7:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host8:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
3983:20190205:142636.937 item "host9:icmppingsec[,1,,24,8000,]" became not supported: fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
4142:20190205:142637.832 SNMP agent item "traffic.in" on host "host10" failed: first network error, wait for 15 seconds
4875:20190205:142638.142 fping failed: (null): can't create raw socket (must run as root?) : Protocol not supported
4875:20190205:142638.143 cannot connect to preprocessing service: Cannot create client socket: [12] Cannot allocate memory.
3946:20190205:142638.149 One child process died (PID:4875,exitcode/signal:1). Exiting ...
5178:20190205:142640.413 cannot read preprocessing service request
zabbix_server [3946]: Error waiting for process with PID 4875: [10] No child processes
3946:20190205:142641.100 syncing history data...
3946:20190205:142641.422 syncing history data... 100.000000%
3946:20190205:142641.422 syncing history data done
3946:20190205:142641.423 syncing trend data...
3946:20190205:142653.355 slow query: 11.930439 sec, "select distinct itemid from trends where clock>=1549371600 and (itemid .....
...81,55024,65775,65810,83155,83157))"
3946:20190205:142659.385 syncing trend data done
3946:20190205:142659.386 Zabbix Server stopped. Zabbix 4.0.4 (revision 89349).
fping version 3.8: -rwsr-xr-x 1 root root 31600 nov 14 2013 /usr/bin/fping
what happen?
Thanks.
what happen?
Thanks.
