Zabbix external script call to Zabbix_sender successful but no data in Zabbix field
  • jjerpseth
    • Oct 2016
    Zabbix external script called with IP address of web server and issues a curl statement which outputs status, response time and number of bytes in response to a temporary file Response.txt with the sample format:
    - Response_code 200
    - Response_time 2.47
    - Response_size 347
    Zabbix_sender is then called to send the Response.txt to our zabbix server. I get a successful response from Zabbix_sender but no data in Zabbix.
    Is there a way to get more debug information from Zabbix_sender to see what is really happening or a way to trap the input from Zabbix_sender in the Zabbix server?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    You should check the receiver log file. If the trapper item is monitored by proxy - proxy log, if by server - server log. You can temporarily increase server/proxy trapper process logging level, e. g.:
    zabbix_server -c /etc/zabbix/zabbix_server.conf -R log_level_increase=trapper
    zabbix_sender [...]
    ... check /var/log/zabbix/zabbix_server.log ...
    ... when finished: ...
    zabbix_server -c /etc/zabbix/zabbix_server.conf -R log_level_decrease=trapper
