String to float or Integer
  • georgehbb
    • Feb 2019
    We have some equipment that unfortunately returns some power level values as string fields. Is there any way to create a template item to store those fields as Numeric float? Is there a workaround to make a conversion string to float?
    We use Zabbix 3.2.6
    Thank you for all the help you can provide us.
