What is the main difference in behaviour between {ITEM.VALUE} macro and {ITEM.LASTVALUE}?
I did some test. Create test trigger and sent to it some data. {ITEM.VALUE} and {ITEM.LASTVALUE} was the same on dashboard page at time when trigger fired, what is fine. Also they values both changed when trigger became "OK". On the page "problems" on the trigger which recently became "OK" values was changed when new item values come to my test item.
So for what 2 different macros are in the Zabbix while their behaviour are the same? Or which tests should outline their differences? Thank you.
