what is the meaning of >0 or =1 parameter
{dms01:web.test.fail[192.168.1.1:91].last()}>0
Tags: None
"{...ITEM.last()}>0" in trigger expression means "fire a trigger if the last value of an ITEM is greater than 0". Equally, "{...ITEM.last()}=1" means "fire a trigger if the last value of an ITEM equals to 1". In your case you use item "web.test.fail". This item returns number of Step that failed in Web scenario. In case of no failures this item returns 0. So I'd use "{dms01:web.test.fail[192.168.1.1:91].last()}<>0".
