Trouble with monitoring services
  • rkruck
    • Mar 2014
    • 9
    I have set up an alert to monitor services in linux (in this case we will use crond).
    [Item]
    Type: Zabbix agent
    Key: proc.num[crond]
    (rest is defalt)
    [Trigger]
    Name: Cron not running on {HOSTNAME}
    Expression: {Custom Linux Templateroc.num[crond].last(0)}<1
    Most of my linux servers this works fine on but I have 9 servers which coincidentally are all RHEL 6.5 servers show up as being down, or under the latest data a value of 0. I went to one of the hosts and ran "zabbix_agentd -t proc.num[crond]" and received:
    proc.num[crond] [u|1]
    I'm lost why it's working on some and not others. I even copied the zabbix_agent.conf file (changing the Hostname= section) from a working server and restarted the agent.
    Any help is appreciated.
    Robert
  • aib
    • Jan 2014
    • 1615
    Do you mind to check if that system has any different daemon like anacron?
    https://access.redhat.com/site/docum...tem_Tasks.html
    May be because of that the daemon crond didn't start and cannot be checked.
    Sincerely yours,
    Aleksey
    • rkruck
      • Mar 2014
      • 9
      service status crond shows that it is running. ps -ef|grep cron shows crond running.
      • rkruck
        • Mar 2014
        • 9
        Not sure if this helps any but I set up another alert to monitor auditd and the same 9 servers show it as failed, yet it's running.
        "zabbix_agentd -t proc.num[auditd]" and received:
        proc.num[auditd] [u|1]
        • rkruck
          • Mar 2014
          • 9
          I found the issue. SELinux is stopping it. I turned it off on my dev/test servers but I need to figure out how to fix it through selinux for our production servers. Unfortunately I know very little about selinux. Has anyone come across this before and may be able to offer assistance.
