Communicate between Zabbix Client and Zabbix Server are having an issue with PSK
  • tienpt
    • Sep 2012
    • 29
    First of all, I am having an issue with communication PSK. Hope you help me understand why? and how to fix it?
    1. Topology
    Zabbix Client: 10.30.3.115
    Zabbix Server: 10.30.3.116
    OS: Ubuntu 16.04 LTS
    Zabbix Server
    sky@zabbix-srv-01:~$ dpkg -l | grep zabbix
    ii zabbix-agent 1:3.2.11-1+xenial amd64 Zabbix network monitoring solution - agent
    ii zabbix-frontend-php 1:3.2.11-1+xenial all Zabbix network monitoring solution - PHP front-end
    ii zabbix-get 1:3.2.11-1+xenial amd64 Zabbix network monitoring solution - get
    ii zabbix-release 3.2-1+xenial all Zabbix official repository configuration
    ii zabbix-server-mysql 1:3.2.11-1+xenial amd64 Zabbix network monitoring solution - server (MySQL)
    Zabbix Client
    sky@graylog-srv-01:~$ dpkg -l | grep zabbix
    sky@graylog-srv-01:~$ ls -lrt /etc/zabbix/
    total 32
    drwxr-xr-x 2 root root 4096 Feb 12 02:20 zabbix_agentd.d
    -rw-r--r-- 1 root root 65 Feb 12 02:20 zabbix_agentd.psk
    -rw-r--r-- 1 root root 10347 Feb 12 02:20 zabbix_agentd.conf.orig
    -rw-r--r-- 1 root root 10364 Feb 13 02:38 zabbix_agentd.conf
    Zabbix Client communicate directly with Zabbix Server without Zabbix Proxy. I installed Zabbix package from repository for both of them.
    2. What did I implement?
    On Zabbix Client, I wrote the agent configuration as below:
    ~$ sudo vim /etc/zabbix/zabbix_agentd.conf
    Server=10.30.3.116 # Zabbix Server
    ServerActive=10.30.3.116
    TLSConnect=psk
    TLSAccept=psk
    TLSPSKIdentity=PSK 007
    TSLPSKFile=/etc/zabbix/zabbix_agentd.psk
    Zabbix agent is running on port 10050
    sky@graylog-srv-01:~$ netstat -tapn | grep 10050
    (Not all processes could be identified, non-owned process info
    will not be shown, you would have to be root to see it all.)
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN -
    tcp6 0 0 :::10050 :::* LISTEN -
    and Zabbix server is running on port 10051
    sky@zabbix-srv-01:~$ netstat -tapln | grep 10051
    tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN -
    tcp6 0 0 :::10051 :::* LISTEN -
    tcp6 0 0 ::1:41360 ::1:10051 TIME_WAIT -
    tcp6 0 0 ::1:41344 ::1:10051 TIME_WAIT -
    tcp6 0 0 ::1:41460 ::1:10051 TIME_WAIT -
    tcp6 0 0 ::1:41396 ::1:10051 TIME_WAIT -
    tcp6 0 0 ::1:41432 ::1:10051 TIME_WAIT -
    Then I added successfully Zabbix Client to Zabbix Server, also enabled PSK at "connections to host" and "connection from host" of Encryption tab in Configuration/ Host. Screen of Zabbix Client appears well, I can create some screens about CPU, network and memory.
Name:	Screen Shot 2019-02-14 at 10.20.53 AM.png
Name:	Screen Shot 2019-02-14 at 10.21.09 AM.png
    After that, I need to create a custom monitoring for Graylog process. Now I need to use zabbix-get, and, from here, I found an issue with PSK.
    3. What happened?
    I declared the IP of Zabbix Agent to Zabbix Agent configuration on Zabbix Server.
    sky@zabbix-srv-01:~$ sudo vim /etc/zabbix/zabbix_agentd.conf
    Server=127.0.0.1,10.30.3.115,10.30.3.116
    And zabbix-get works on Zabbix Server
    sky@graylog-srv-01:~$ zabbix_get -s 10.30.3.116 -k 'proc.num[zabbix_server,zabbix]'
    28
    But, it is not working with Zabbix Client
    sky@graylog-srv-01:~$ zabbix_get -s 10.30.3.115 -k 'proc.num[zabbix_server,zabbix]'
    zabbix_get [8674]: Check access restrictions in Zabbix agent configuration
    Although, I already declared IP of Zabbix Client at Server directive at /etc/zabbix/zabbix_agentd.conf. So I traced the log file and found the issue with PSK.
    Zabbix server log
    sky@zabbix-srv-01:~$ tail -f /var/log/zabbix/zabbix_server.log
    31582:20190213:023538.060 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:023625.636 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:023734.472 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:023808.172 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:023900.675 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:024100.690 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31583:20190213:024300.703 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31582:20190213:024500.717 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:024700.732 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    31581:20190213:024809.099 cannot send list of active checks to "10.30.3.115": connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    Zabbix client log
    sky@graylog-srv-01:~$ zabbix_get -s 127.0.0.1 -k 'proc.num[zabbix_server,zabbix]'
    zabbix_get [29503]: Check access restrictions in Zabbix agent configuration
    29495:20190213:031609.353 no active checks on server [10.30.3.116:10051]: connection of type "TLS with PSK" is not allowed for host "Zabbix server"
    29494:20190213:024812.549 failed to accept an incoming connection: from 127.0.0.1: unencrypted connections are not allowed
    As I see, the PSK is having an issue. So now, my question are:
    - How to fix an issue "zabbix_get [8674]: Check access restrictions in Zabbix agent configuration"
    - How to fix an issue with PSK?
    - What did I misconfigured?
    Thank you so much!!!
  • ingus.vilnis
    • Mar 2014
    • 908
    Awesome level of detail in your description.
    Let's brake it down into two issues.
    Zabbix Get first.
    You can't use the zabbix_get in the unencrypted way anymore as you used to do before. Add the additional PSK info so the command looks something like this:
    zabbix_get -s 10.30.3.115 -k 'proc.num[zabbix_server,zabbix]'  --tls-connect=psk --tls-psk-identity="PSK 007" --tls-psk-file=/etc/zabbix/zabbix_agentd.psk
    Check the docs here: https://www.zabbix.com/documentation...cation_example
    Another issue is that you get misleading messages in the logs. And they are because the Hostname setting in your zabbix_agentd.conf file is left to default "Zabbix server" whereas you need it to match the name which you defined in the web interface, in your case Hostname=graylog-srv-01
    Restart the agent to apply and check the logs again.
    Hope this helps!
    • tienpt
      • Sep 2012
      • 29
      Thank you so much @ingus.vilnis
      Another issue was solved. Zabbix Get still didn't solve. I used to run the below command
      skylab@graylog-srv-01:~$ zabbix_get -s 10.30.3.115 -k 'proc.num[zabbix_agentd,zabbix]' --tls-connect=psk --tls-psk-identity="PSK 007" --tls-psk-file=/etc/zabbix/zabbix_agentd.psk
      zabbix_get [11511]: Warning: SSL_shutdown() with 10.30.3.115 returned error code 5: TLS read warning alert "close notify"
      zabbix_get [11511]: Get value error: connection closed during read
      zabbix_get [11511]: Check access restrictions in Zabbix agent configuration
      Then the log generated
      11445:20190213:225423.072 failed to accept an incoming connection: connection from "10.30.3.115" rejected, allowed hosts: "10.30.3.116"
      11444:20190213:225429.137 failed to accept an incoming connection: connection from "10.30.3.115" rejected, allowed hosts: "10.30.3.116"
      11444:20190213:225640.934 failed to accept an incoming connection: connection from "10.30.3.115" rejected, allowed hosts: "10.30.3.116"
      • ingus.vilnis
        • Mar 2014
        • 908
        You can't run zabbix_get on the server which you are actually monitoring. Do this on the Zabbix server.
        If you still need to tun zabbix_get on the graylog-srv-01 then add 127.0.0.1 to the Server setting in zabbix_agentd.conf. But I am now not sure why you would want to do this in the first place. zabbix_get is great for testing communication typically between server and agent.
        • tienpt
          • Sep 2012
          • 29
          Firstly, the command still didn't succeed.
          zabbix_get [11701]: Get value error: connection closed during read
          zabbix_get [11701]: Check access restrictions in Zabbix agent configuration
          and log
          11698:20190213:230858.612 failed to accept an incoming connection: connection from "10.30.3.115" rejected, allowed hosts: "127.0.0.1,10.30.3.116"
          However, the Warning: SSL_shutdown() with 10.30.3.115 returned error code 5: TLS read warning alert "close notify" have gone :-)
          Another point, I got your recommendation about zabbix get. It means that I need to create a library of PSK on the Zabbix Server side? to store all of PSK of Zabbix Client. As you said before: "You can't use the zabbix_get in the unencrypted way anymore as you used to do before. Add the additional PSK info so the command looks something like this:"
          Then it should look like
          skylab@zabbix-srv-01:~$ zabbix_get -s 10.30.3.115 -k 'proc.num[zabbix_agentd,zabbix]' --tls-connect=psk --tls-psk-identity="PSK 007" --tls-psk-file=/etc/zabbix/zabbix_agentd.psk
          • tienpt
            • Sep 2012
            • 29
            You are right! I have just copied the PSK of Zabbix Client to Zabbix Server, then it worked as well
            skylab@graylog-srv-01:~$ scp /etc/zabbix/zabbix_agentd.psk [email protected]:/tmp
            and
            skylab@zabbix-srv-01:~$ zabbix_get -s 10.30.3.115 -k 'proc.num[zabbix_agentd,zabbix]' --tls-connect=psk --tls-psk-identity="PSK 007" --tls-psk-file=/tmp/zabbix_agentd.psk
            7
            • ingus.vilnis
              • Mar 2014
              • 908
              Hold on.
              Don't run zabbix_get on graylog-srv-01 for now. Run it from zabbix-srv-01 !
              And don't mess with PSK on Zabbix server. That was not what I meant with that comment.
              • ingus.vilnis
                • Mar 2014
                • 908
                Ok, now you got this running. Nice.
                • tienpt
                  • Sep 2012
                  • 29
                  skylab@zabbix-srv-01:~$ zabbix_get -s 10.30.3.115 -k 'proc.num[graylog-server,graylog]' --tls-connect=psk --tls-psk-identity="PSK 007" --tls-psk-file=/tmp/zabbix_agentd.psk
                  1
                  Here is what I need to do. I am going to create an script or something like that to monitor Graylog process at graylog-srv-01. On this topic, I learned from you about best practice for using Zabbix Get. I am a newbie, then my knowledge is breaking by google. [I need to read the book to structure my knowledge]
                  So now, of course, I don't need to run Zabbix Get on Client [graylog-srv-01]. Thus I need to organize the PSK's Client on Server.
                  I see that's what you want to let me know.
                  • ingus.vilnis
                    • Mar 2014
                    • 908
                    Ok, that's fine.
                    But still why you need Zabbix Get if (what I think) you really need this configured in Zabbix from web interface?
                    • tienpt
                      • Sep 2012
                      • 29
                      If I don't mess with PSK on Zabbix Server, Zabbix Get could to succeed.
                      1
                      zabbix_get [27289]: ERROR: parameter "--tls-psk-identity" is defined, but "--tls-psk-file" is not defined
                      zabbix_get [27293]: ERROR: parameter "--tls-connect" value requires "--tls-psk-file", but it is not defined
                      zabbix_get [27296]: Check access restrictions in Zabbix agent configuration
                      And log on Client
                      11698:20190213:232251.765 failed to accept an incoming connection: from 10.30.3.116: unencrypted connections are not allowed
                      • tienpt
                        • Sep 2012
                        • 29
                        Ah I need Zabbix Get because some guys [from result's Google] let me should use Zabbix Get to create an script to monitor Graylog process or another Linux process. Could you let me know what is best practice to monitor Linux process on Client with Zabbix?
                        • ingus.vilnis
                          • Mar 2014
                          • 908
                          If you just need to list the process count then use the same "proc.num[graylog-server,graylog]" item and configure it in a Zabbix Template. Are you familiar with that?
                          If you need something more then need to know what it is.
                          • tienpt
                            • Sep 2012
                            • 29
                            I don't familiar with that. But, I can read Zabbix documentation and try it. Do you have any advice for me?
                            • tienpt
                              • Sep 2012
                              • 29
                              #15
                              My purpose is monitoring completely Linux process to keep the monitoring 24/7. Anytime, when the Linux process have any issue, then stop, I will know as soon as possible and go to fix.
