First of all, I am using:
Is it possible to config multiple LogType in zabbix_server.conf [ also zabbix_agentd.conf]. I have tried to set multiple with command, then started failure because the configuration error.
Here is correct configuration
### Option: LogType
And here is what I want. But, Zabbix could not start.
As I see, Zabbix 3.2 doesn't support multiple LogType. Am I right? Also I don't know if the latest version of Zabbix support?
Sometime, I want to store log to syslog & graylog. In fact, I really want to know if Zabbix support this feature or not. Could you please share me some knowledge about this?
Thank you so much!
Ubuntu 16.04 LTS
Zabbix Server 3.2 from repository
App/ Syslog sends to graylog.
### Option: LogType
# Specifies where log messages are written to:
# system - syslog
# file - file specified with LogFile parameter
# console - standard output
# Mandatory: no
# Default:
# LogType=file
LogType=system
# system - syslog
# Mandatory: no
# Default:
# LogType=file
LogType=system
### Option: LogType
# system - syslog
# Mandatory: no
# Default:
# LogType=file
LogType=system, file
# system - syslog
# Mandatory: no
# Default:
# LogType=file
Thank you so much!
