missing mysql db package for zabbix 4.x?
  • speculatrix
    • Jan 2018
    there's a package called zabbix30-dbfiles-mysql.noarch
    but there doesn't appear to be an equivalent package for zabbix 4, looking here, I don't see anything.
    I am creating a brand new zabbix server instance and have these packages:
    zabbix-agent-4.0.4-1.el7.x86_64
    zabbix-server-mysql-4.0.4-1.el7.x86_64
    zabbix-web-4.0.4-1.el7.noarch
    zabbix-web-mysql-4.0.4-1.el7.noarch
    zabbix-web-pgsql-4.0.4-1.el7.noarch
    but there doesn't appear to be a DB setup script in any of them :-(
  • LenR
    • Sep 2009
    • 1011
    They changed the name and merged them somewhere along the way, look for /usr/share/doc/zabbix-server-mysql-4.*/create.sql.gz . It's part of the zabbix-server-mysql rpm.
    • speculatrix
      • Jan 2018
      aha, right, I see it now, thanks, yup, I can decompress and see the SQL
      /usr/share/doc/zabbix-server-mysql-4.0.4/create.sql.gz
      thanks
      • sjsondrup
        • May 2019
        Hi
        I'm new here and just installed from *.deb packages into my server.
        All goes fine except the create.sql.gz file is missing in the downloaded packages, so unable to get sql configured.
        File is NOT in /usr/share/doc/zabbix-server-mysql*/create.sql.gz as it is supposed to be.
        (File does not show up on a global search on the server either.)
        Where do I get it pls.
        Thanks in advance
        Søren
