Dashboard rendering mangled after 3.2 -> 3.4 upgrade even after cache cleared
  • zinjaxx
    • Feb 2019
    I upgraded from 3.2 to 3.4. When I view the new dashboard in a wide screen (16:10) monitor it renders as expected. When viewing on a laptop with a 11 inch screen (HP EliteBook) or a 4:3 monitor the dashboard appears to render as if on a mobile device. When this happens the widgets all overlap and appears messy. Same behavior when viewing the dashboard on a iPhone (safari,chrome) browser as well.
    I have cleared the cache (including everything - cookies, history etc etc) and am unable to resolve this.
    As a workaround I created a custom screen and added the same widgets found on the dashboard and this works fine. Is there anything I can "tweak" to make the dashboard work as before?
    Thanks.
  • zinjaxx
    • Feb 2019
    I think I have found a solutions - noticed the blue-theme.css and the .bak file sizes were different. Replacing the new file with the backup and clearing the caches helped me resolve this issue. The dark-theme.css file doesn't appear to have changed during the upgrade. For reference I am running Zabbix 3.4.15 on Ubuntu 16.04.5 LTS. The upgrade was done using the instructions at https://www.zabbix.com/documentation.../debian_ubuntu .
    • zux
      • Sep 2018
      • 97
      offtopic: why didn't you upgrade to the latest 4.0?
      • zinjaxx
        zinjaxx commented
        Recall running 3.4 was a prerequisite for upgrading to 4.0. I will attempt that now that the dashboard issue has been resolved.
    • zux
      • Sep 2018
      • 97
      not really, you could have upgraded directly.
