Zabbix configuration cache
  • delfredo
    • Feb 2019
    Hello everybody,
    i have a classic issue of Zabbix configuration cache
    This is my configuration:
    Zabbix 4.0.4 (installed on a Debian 8.5)
    MySql Database
    Number of hosts (enabled/disabled/templates) 206 135 / 22 / 49
    Number of items (enabled/disabled/not supported) 10541 8745 / 1215 / 581
    Number of triggers (enabled/disabled [problem/ok]) 3237 2378 / 859 [2 / 2376]
    The thing is, if i uncomment the parameter CacheSize and put 16M or more, during 5mn the problem is solved.
    Then the Zabbix-Server service stops and restart with the parameter CacheSize commented (returning to 8M by default). The server auconfigure itself after a crash??
    I have nothing related to this problem in the zabbix_server log except the restart event.
    Does anybody have this (weird) issue?
  • zux
    • Sep 2018
    • 97
    Zabbix server doesn't edit it's configuration file. Either you are not doing it correctly yourself or something outside of Zabbix is moving it back.
