Zabbix Agent 4.0.X - system.run escaping square brackets
  • james.cook000@gmail.com
    • Apr 2018
    • 49
    Hi People,
    Running into a slight issue I believe seems to be effecting Zabbix 4.0.X agents.
    On version 3.4.X:
    H:> zabbix_get -s 127.0.0.1 -k system.run["echo On a 3.4.X Agent a right square bracket does work ]"]
    echo On a 3.4.X agent a right square bracket does work ]
    On version 4.0.X:
    H:\>zabbix_get -s 127.0.0.1 -k system.run["echo On a 4.0.X agent a right square bracket does NOT work ]"]
    ZBX_NOTSUPPORTED: Invalid item key format.
    I have tried all sorts of quotation and escaping to no avail as I get the error 'ZBX_NOTSUPPORTED: Invalid item key format.'
    Has anyone experienced this before I put a Zabbix issue in?
    Cheers
    James
  • zux
    • Sep 2018
    • 97
    looks like a regression, works on 3.4 but not on 4.0.
    I would recommend to create a bug report.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      If I understand correctly, It's already there https://support.zabbix.com/browse/ZBX-15697
