numeric integer (64bit) is not 64bit -- 1531950
  • jshshawca
    • Jul 2006
    i am running a remote command that returns a large value and the custom multiplier is 1024. the type is set to numeric interger (64bit) and it is set to delta.
    when the calculated value (returned * 1024) exceeds 999,999,999,999 it causes issues in caculating the delta..
    in the zabbix_server.log
    NORMAL ENTRY (smaller number):
    029292:20060731:131730 ITEM_STORE_SPEED_PER_SECOND(system.run[iostat -dk | awk '{total += $6} END {print total}'],591648006144.000000,0.000000)
    ERRORONEOUS ENTRY:
    029292:20060731:131730 ITEM_STORE_SPEED_PER_SECOND(system.run[iostat -dk | awk '{total += $5} END {print total}'],999999999999.999878,0.000000)
    Whatever the value over a certian nubmer it reports with 999999999999.999878 as the returned value and calculates the delta incorrectly causing bogus data.
  • jshshawca
    • Jul 2006
    Bump Bump Bump
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Thanks for reporting this. To be verified and fixed if required.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
