ORA-933 when using trends with zabbix plugin in Grafana
  • lefterhs
    • Feb 2019
    Grafana: 5.3.4
    Zabbix: 3.2.4
    Oracle DB with the zabbix repository:12.2
    Hello.
    I have enabled the trends option on my zabbix data source with after=30d and range=30d.
    When I select the appropriate range on my dashboards to use trends (eg now -30d) I get “No data points” on my graphs.
    In Oracle’s alert log, I get the following messages, relevant to this:
    WARNING: too many parse errors, count=500 SQL hash=0x248f5006
    PARSE ERROR: ospid=26861, error=933 for statement:
    2019-02-28T13:06:49.851786+02:00
    SELECT t.* FROM trends_uint AS t WHERE t.clock>=:“SYS_B_0” AND t.clock<=:“SYS_B_1” AND t.itemid=:“SYS_B_2”
    Additional information: hd=0x1bb4211f0 phd=0x1c13b4ec0 flg=0x28 cisid=84 sid=84 ciuid=84 uid=84
    These errors are:
    ORA-00933: SQL command not properly ended
    So, the above query is not executed in Oracle:
    SQL> SELECT t.* FROM trends_uint AS t WHERE t.clock>=1536613200 AND t.clock<=1536614200 AND t.itemid=93624;
    ERROR at line 1:
    “AS” should not be used for table aliases in Oracle.
    The correct syntax is:
    SQL> SELECT t.* FROM trends_uint t WHERE t.clock>=1536613200 AND t.clock<=1536614200 AND t.itemid=93624;
    ITEMID CLOCK NUM VALUE_MIN VALUE_AVG VALUE_MAX
    93624 1536613200 12 5843 7709 9779
    Is this a zabbix or grafana issue?
