Problem with upgrade frontend
  • barto_95
    • Nov 2018
    • 16
    After upgrade the GUI don't work
    I view the version of paquet on my debian :
    zabbix-agent 1:4.0.4+dfsg-
    zabbix-frontend-php 1:4.0.0+dfsg-1
    zabbix-release 3.5-1+stretch
    zabbix-server-mysql 1:4.0.4+dfsg-1
    I upgrade zabbix-frontend-php to :
    zabbix-frontend-php 1:4.0.4+dfsg-1
    But when a Login to wsebui I have the wizard for configuration database etc..
    But I block on this screen
    For information I change the the /etc/zabbix/web to www-data:www-data and chmod 777 -R
    but Not possible to create configuration....
    I test to configure manually the zabbix_conf.php but If I click on "button "Finish"
    the page loads and stays the same
    Do you help me please ?
    thank's
  • Atsushi
    • Aug 2013
    • 2028
    Since the name of the package contains the name dfsg, it seems that it is not a Zabbix official package. Is not it a different directory structure from the Zabbix official package?
    For example, it seems that "/etc/zabbix/zabbix.conf.php" appears as the save destination of the setting file as long as you see the attached image file. It is not the "/etc/zabbix/web" directory.
    Please download the configuration file and save it as "/etc/zabbix/zabbix.conf.php" as shown on the screen message.
    • barto_95
      • Nov 2018
      • 16
      YEs the problem is I copy in wrong path
      Thank's you
