Zabbix Database Error
  • TheCookieMonster
    • Jul 2017
    • 48
    We lost power to our server room, and when the Zabbix Server came back up, when browsing to the frontend Zabbix page, we are presented with the error:
    'Error connecting to database: The server requested authentication method unknown to the client'
    Looking on the Zabbix Server, zabbix-server.log and zabbix-agentd.log show they are connected to the database fine, so it looks like it is just the frontend having problems.
    We are using:
    Ubuntu 18.04
    MySQL 8.0.15
    Zabbix 4.0.5
    Can anyone help me understand how to investigate and fix this?
  • max.ch.88
    • Oct 2018
    • 206
    What does mysql write in log? Do you can to do the manual connect between frontend and mysql?
    • aravivek07
      • Feb 2021
      Is there any solution for this? I'm getting the same error
      • The server requested authentication method unknown to the client
      • NgRox
        • Jun 2022
        • 45
        2 possible causes
        When logging into Zabbix for the first time, you will be asked to enter the database connection details, you enter a complicated password and get the error "The server requested authentication method unknown to the client."
        This is possibly due to the PHP front-end not being aware of MySQL's password hashing requirement. So you can change the Zabbix user in the database to use the mysql_native_password option.
        Resolution:
        Exec in your DB:
        ALTER USER 'zabbix'@'localhost' IDENTIFIED WITH mysql_native_password BY 'password';
        FLUSH PRIVILEGES;
        Restart MySQL
