nstat not returning values to zabbix
  • min0sys
    • Mar 2019
    Hi guys,
    I`m trying to use zabbix in this configuration :
    #server1:
    zabbix-agent   4.0.5-1+xenial
    Ubuntu 16.04.5 LTS
    Linux version 4.4.0-142-generic (buildd@lgw01-amd64-033) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
    nstat -version : nstat utility, iproute2-ss151103
    # server2:
    zabbix-agent  4.0.5-1+trusty
    Ubuntu 14.04.5 LTS
    Linux version 3.13.0-164-generic (buildd@lcy01-amd64-015) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.4) ) #214-Ubuntu SMP
    nstat -version : nstat utility, iproute2-ss131122
    In both cases, I`m using user parameter conf :
    cat /etc/zabbix/zabbix_agentd.d/userparameter_tcpip.conf
    UserParameter=tcpip.stats[*],nstat -az|grep "$1\ "|awk '{print $$2}'
    And this is the result from zabbix :
    Server1: getting value of tcpip.stats[TcpExtTCPKeepAlive]:
    root@server1:~# nstat -az | grep -i TCPKeepAlive
    TcpExt[B]TCPKeepAlive[/B]              40813              0.0
    root@server1:~# cat /proc/net/netstat |grep -i TCPKeepAlive
    TcpExt: [B]TCPKeepAlive[/B]
    root@server1:~# zabbix_agentd -t tcpip.stats[TcpExtTCPKeepAlive]
    tcpip.stats[TcpExtTCPKeepAlive]               [t|40816]
    Server2: not getting values of tcpip.stats[TcpExtTCPKeepAlive]:
    root@server2:~# nstat -az | grep -i TCPKeepAlive
    root@server2:~# cat /proc/net/netstat |grep -i TCPKeepAlive
    root@server2:~# zabbix_agentd -t tcpip.stats[TcpExtTCPKeepAlive]
    tcpip.stats[TcpExtTCPKeepAlive]               [t|]
    From my understanding, this might be related to version of kernel and/or iproute utility. What I`m not sure about, why zabbix insist on checking parameter which doesn`t exist in /proc/net/netstat , while using userparameter file?
    @Admins, please check this, I`m getting on main page, when clicking on read more :
    Invalid Page URL. If this is an error and the page should exist, please contact the system administrator and tell them how you got this message.
Name:	Screenshot 2019-03-20 at 11.43.15.png
    Thank you
  • max.ch.88
    • Oct 2018
    • 206
    Zabbix agent does not know anything about your system settings. Exception handling is your script's task.
    • min0sys
      • Mar 2019
      Hi max.ch.88 ; I might not get it correct.
      My script is only getting data from command :
      nstat -az
      , and parse/assign value. And I can confirm, it is working on servers, which have newer versions of kernel/iproute2 utility.
      What I`m trying to say is, that if I run simple command from shell :
      nstat -az
      I will not get the value. Same is for
      . Value is not there.
      That is correct, and expected behaviour on systems with older iproute2 utility, and this is all what my script do (run the nstat command, generate output, read the output, parse values/strings) What I do not understand, why zabbix still generating alerts for values which doesn`t exists at all? 90% of values are OK, monitored, zabbix recognize them from nstat output. But the rest is generating alerts. I tried to look everywhere, but so far, didn`t find out, why.
      • max.ch.88
        • Oct 2018
        • 206
        Originally posted by min0sys
        ... What I`m not sure about, why zabbix insist on checking parameter which doesn`t exist in /proc/net/netstat , while using userparameter file?
        Hi.
        Zabbix doesn't insist on checking parameter. It does what you told it - nstat -az|grep "TCPKeepAlive\ "|awk '{print $$2}'. And if you received nothing when executed nstat -az|grep "TCPKeepAlive\ "|awk '{print $$2}' manually, obviously you will receive nothing using zabbix.
        The value cannot be empty. This is an error for zabbix. The value must be at least 0. You need exception handling
        a=$(nstat -az|grep "$1\ "|awk '{print $$2}'); if [[ -z $a ]]; then echo 0; else echo $a; fi
        • min0sys
          • Mar 2019
          Hi max.ch.88, I completely agree with you on this. If I receive nothing from nstat -az ; or recieve nothing when do cat /etc/proc/netstat, then alert should not be generated. In this case I would be more than happy if it will work this way as you wrote.
          But the alert is generated. TcpExtTCPKeepAlive was just example. My userparameter_tcpip.conf command generate those alerts to zabbix:
Name:	Screenshot 2019-03-29 at 11.28.10.png
          So I went to server, and check the unsupported values for key tcpip.stats + example of working TCPExt values (server name was removed): Click image for larger version
          I hope, this will provide much better view on this. I was told that Low Level Discovery should help here, but this is very last option here. I want to understand this behaviour first.
          • max.ch.88
            • Oct 2018
            • 206
            Do you want to understand why the alert is generated? Why do the items have status "not supported"?
            Because the items have "Type of information" - Numeric. The zabbix server expects the numeric value, but receives empty value.
            tcpip.stats[TcpExtTCPSynRetrans] [t|]
            tcpip.stats[TcpExtTCPFastOpenActiveFail] [t|]
            tcpip.stats[TcpExtTCPFromZeroWindowAdv] [t|]
            Why does the server receive empty value?
            Because your system doesn't have those counters.
            #nstat -az | grep -P "TcpExtTCPKeepAlive|TcpExtTCPSynRetrans|TcpExt TCPF astOpenActiveFail|TcpExtTCPFromZeroWindowAdv"
            empty value
            What could you do?
            Solution 1: disable those items for the host.
            Solution 2: repair or update the kernel and/or the iproute utility on the host.
