change trigger severity automatically ?
  • fjacob
    • Feb 2019
    I use Zabbix in version 4.0, and I'd like to modify automatically the severity of a trigger.
    In order, to know the status of my differents router, I make trigger based on simple check (ping).
    A trigger, with severity "warning" when a ping is ont ok
    A trigger, with severity "High" when a ping is ont ok during 2 hours.
    A trigger, with severity "Disaster" when a ping is ont ok during 4 hours.
    Is it possible to change automatically the severity of the trigger with time.
    I hope, tou understand my means because my english is not so good.
    thanks,
