Troubles with perfomance when use zabbix proxy
  • altervast
    • Jun 2014
    Hi everybody!
    I have troubles with proxy usage.
    My infrastructure: 3 remote networks sites A,B,C
    Site A is monitored by Zabbix server itself,
    Sites B&C are monitored by zabbix proxies in these sites.
    Here are the data from zabbix server:
    Number of hosts (monitored/not monitored/templates) 283 192 / 19 / 72
    Number of items (monitored/disabled/not supported) 26414 24803 / 13 / 1598
    Number of triggers (enabled/disabled) [problem/ok] 5426 3339 / 2087 [26 / 3313]
    Required server performance, new values per second 208.4 -
    The problems are:
    1. Zabbix queue is 6K elements now
    2. Values processed by Zabbix server per second are less than 0.5K
    The graphs are similar to all the servers (zabbix server and two proxies)
    But QUEUE OF ITEMS TO BE UPDATED is different!!!
    Proxy 5 seconds 10 seconds 30 seconds 1 minute 5 minutes More than 10 minutes
    R-proxy-01 1089 3964 3280 704 314 483
    S-proxy-01 52 303 124 72 67 17
    Server 33 1 0 0 0 0
    In case of decreasing the item new values request time, the queue could reach 20K on all servers quickly.
    We have provided a few experiments:
    1. We have reconfigured the hosts to report to zabbix server instead of proxy in one site. The queue went down below 0.5K as result.
    2. We have disabled from the monitoring turned off hosts. The queue became equivalent to processed value graph.
    The question is: What should I configure to be able to use proxy correctly:
    1. without data leaks
    2. with correctly processed switched off hosts with enabled monitoring.
    Proxy configs and my.cnf attached below.
    my.cnf of R-proxy-01
    max_connections=300
    innodb_flush_log_at_trx_commit=2
    innodb_buffer_pool_size=4G
    innodb_thread_concurrency=8
    innodb_flush_method=O_DIRECT
    innodb_data_file_path=ibdata1:10M:autoextend
    innodb_file_per_table=1
    innodb_log_file_size=512M
    query_cache_size=128M
    join_buffer_size=128M
    table_cache=128M
    thread_cache_size=128M
    zabbix_proxy.conf of R-proxy-01
    ProxyMode=0
    ProxyLocalBuffer=1
    ProxyOfflineBuffer=12
    HeartbeatFrequency=60
    ConfigFrequency=600
    DataSenderFrequency=1
    StartPollers=100
    StartIPMIPollers=5
    StartPollersUnreachable=20
    StartTrappers=10
    StartPingers=20
    CacheSize=500M
    StartDBSyncers=20
    HistoryCacheSize=500M
    HistoryTextCacheSize=500M
    Timeout=3
    TrapperTimeout=300
    UnreachablePeriod=45
    UnavailableDelay=60
    UnreachableDelay=15
  • LenR
    • Sep 2009
    • 1011
    Do the agents list their proxy's IP to allow access?
    If you're 2.2, add the zabbix_proxy template to the proxies, check for busy internal and data gathering processes. Also check the internal items on the server.
    • Palmertree
      • Sep 2005
      • 746
      If you use the Zabbix internal monitoring make sure that the proxy server you are monitoring is processed by the same proxy server or not another zabbix server. The metrics returned are for which every device does the polling for Zabbix internal monitoring for zabbix metrics.
