I have written a python script to monitor allocation on vgdocker and added it as an item to Zabbix. Although I get the right value with zabbix_agentd on client server(dockerserver); zabbix_get on proxy server generates error:
I ran the command with zabbix user (su -s /bin/bash zabbix)
$ zabbix_agentd -t vg.allocated.pool[Allocated]
vg.allocated.pool[Allocated] [t|25.36]
$ zabbix_agentd -V
zabbix_agentd (daemon) (Zabbix) 4.0.3
Revision 87993 20 December 2018, compilation time: Dec 20 2018 11:29:54
# zabbix_get -s dockerserver -k "vg.allocated.pool[Allocated]"
Traceback (most recent call last):
File "/etc/zabbix/zabbix_agentd.d/vgdocker.py", line 29, in <module>
get_connection(parse_args.state_name)
File "/etc/zabbix/zabbix_agentd.d/vgdocker.py", line 21, in get_connection
poolused = allocated_pool.split()[-1][:-1]
IndexError: list index out of range
# zabbix_get -V
zabbix_get (Zabbix) 4.0.3
Could you assist me what to check?
Thanks,
Edit: Solved by changing sudo permission to run the whole script rather than vgdisplay command.
$ zabbix_agentd -V
# zabbix_get -V
Thanks,
