Monitoring Embedded Systems
  • akj
    • Apr 2019
    What do you do if you're monitoring something like an embedded PHT player where the image is more or less fixed? Just doing ping/port monitoring I can figure out; but in the host definition it is insisting on one form of either Agent/JMX/IPMI/SNMP and the system just doesn't have any of those without re-spinning a custom version which is impractical.
