Hello everyone,
I need to correlate between module name to sensor name in item prototype which have different SNMP OID on Cisco 4500
here's my config
LLD rule:
discovery[{#SNMPVALUE},1.3.6.1.4.1.9.9.13.1.3.1.2,{#ENT_NAME },1.3.6.1.2.1.47.1.1.1.1.7]
LLD filter:
Only module linecard and supervisor that have temperature sensor, other modules are ignored.
A OR B (tried A AND B no result in latest data)
A {#ENT_NAME} matches Linecard.+|Supervisor.+
B {#SNMPVALUE} matches Air inlet|Air inlet remote|Air outlet|Air outlet remote|Stub [AB]|XPP|VFE|NFE|CPU|FPGA
item proto:
{#ENT_NAME} {SNMPVALUE}: Temperature status
expected item proto result:
each module has multiple sensor
Module Sensor Temperature Status
1 Air inlet 28C (44C,59C,62C) ok
1 Air inlet remote 35C (47C,61C,64C) ok
1 Air outlet 33C (47C,62C,65C) ok
1 Air outlet remote 38C (52C,66C,69C) ok
3 Stub A 36C (58C,71C,74C) ok
3 Stub B 28C (54C,68C,71C) ok
3 XPP 46C (67C,81C,84C) ok
3 VFE 59C (79C,90C,93C) ok
3 NFE 45C (68C,80C,83C) ok
3 CPU 53C (69C,83C,86C) ok
3 FPGA 35C (57C,71C,74C) ok
4 Stub A 33C (58C,71C,74C) ok
4 Stub B 27C (54C,68C,71C) ok
4 XPP 44C (67C,81C,84C) ok
4 VFE 52C (79C,90C,93C) ok
4 NFE 42C (68C,80C,83C) ok
4 CPU 47C (69C,83C,86C) ok
4 FPGA 32C (57C,71C,74C) ok
expected result:
Linecard(slot 1) Air inlet:
Linecard(slot 1) Air inlet remote:
etc.
Supervisor(slot 3) CPU: Temperature status
Supervisor(slot 3) FPGA: Temperature status
and so on
question:
how do I sort the wanted sensor name to correct module name in item prototype? tried context macro not working in item proto name
many thanks
here's my config
LLD rule:
LLD filter:
item proto:
expected result:
etc.
and so on
question:
many thanks
