zabbix_sender with JSON for LLD
  • mauro
    • Jan 2017
    • 94
    Hello.
    I search in the forum and on the Web, I found instructions but work at 100%.
    Briefly: I have created a template, on this a discovery rules key: status.backup, no filters, type zabbix trapper.
    One item prototype: type zabbix trapper, name Backup Status {#PLANS}, text, no more.
    Craete an host test_backup_host and linked this template.
    Ok, now I prepared a JSON File:
    test_backup_host status.backup{"data":[{"{#PLANS}":"Daily Backup"}]}
    and use zabbix_sender:
    zabbix_sender -z serverName -i file.json
    Perfect, in the host appear the new discoverd item status.backup[Daily Backup].
    Now I want to valorize it. With the sender and the -o it works but I want to execute only one data send, just with the json.
    I try many "configurations":
    test_backup_host status.backup{"data":[{"{#PLANS}":"Daily Backup","{status.acronis[Daily Backup]}":"ok"}]}
    test_backup_host status.backup{"data":[{"{#PLANS}":"Daily Backup","{status.acronis['Daily Backup']}":"ok"}]}
    test_backup_host status.backup{"data":[{"{#PLANS}":"Daily Backup","value":"ok"}]}
    nothing.
    the Item was created but the value still remain null.
    Where is the mistake?
    Thx
  • mauro
    • Jan 2017
    • 94
    I'm stupid.
    The key is status.backup and this is for autodiscover... I can't (in the same row) set the value for the new discovered item.
    two line is necessary for me:
    test_backup_host status.backup {"data":[{"{#PLANS}":"Daily Backup"}]}
    test_backup_host status.backup[Daily Backup] ok
    but in this way, sometimes the second row don't set the value: probably because the item has not yet been created, ie a few milliseconds have passed since the request from the previous sender.
    Other ideas are welcome.
