Zabbix agent will not install under PowerShell function
  • markfree
    • Apr 2019
    • 875
    Steps to reproduce:
    I have created a PowerShell script to install Zabbix Agent on a Windows server 2008. I can execute zabbix agent commands whitin CMD with no problem, but when I try to start the "--install -c <configuration_file>" on my script it fails.
    My script stops and uninstall zabbix agent successfully. But, when I try to install it again, it gives an error showing
    "zabbix_agentd.exe [5952]: unrecognized option `--install --config C:\zabbix\conf\zabbix_agentd.conf'"
    1. I have Zabbix Agent installed on C:\zabbix\
    2. Configuration file is located at C:\zabbix\conf\zabbix_agentd.conf
    My script:
    $agenteZabbix    = "C:\zabbix\bin\zabbix_agentd.exe"
     function PulaLinha {     timeout /T 1 /NOBREAK > $null     Write-Host "`n`n"     }  function ZabbixComando ($comando) {     & $agenteZabbix $comando          PulaLinha     }  ZabbixComando -comando '--stop' ZabbixComando -comando '--uninstall' ZabbixComando -comando '--install --config C:\zabbix\conf\zabbix_agentd.conf' ZabbixComando -comando '--start'
    Result:
     zabbix_agentd.exe [20144]: service [Zabbix Agent] stopped successfully  zabbix_agentd.exe [13196]: service [Zabbix Agent] uninstalled successfully zabbix_agentd.exe [13196]: event source [Zabbix Agent] uninstalled successfully  zabbix_agentd.exe [18176]: unrecognized option `--install --config C:\zabbix\conf\zabbix_agentd.conf' usage:   zabbix_agentd.exe [-c config-file]   zabbix_agentd.exe [-c config-file] -p   zabbix_agentd.exe [-c config-file] -t item-key   zabbix_agentd.exe [-c config-file] -i [-m]   zabbix_agentd.exe [-c config-file] -d [-m]   zabbix_agentd.exe [-c config-file] -s [-m]   zabbix_agentd.exe [-c config-file] -x [-m]   zabbix_agentd.exe -h   zabbix_agentd.exe -V  zabbix_agentd.exe [15944]: ERROR: cannot open service [Zabbix Agent]: [0x0000042 4] The specified service does not exist as an installed service.
    Expected:
    When I do it all manually, it gives me no errors
     C:\zabbix\bin>zabbix_agentd.exe --stop zabbix_agentd.exe [21260]: service [Zabbix Agent] stopped successfully  C:\zabbix\bin>zabbix_agentd.exe --uninstall zabbix_agentd.exe [19888]: service [Zabbix Agent] uninstalled successfully zabbix_agentd.exe [19888]: event source [Zabbix Agent] uninstalled successfully  C:\zabbix\bin>zabbix_agentd.exe --install -c C:\zabbix\conf\zabbix_agentd.conf zabbix_agentd.exe [5968]: service [Zabbix Agent] installed successfully zabbix_agentd.exe [5968]: event source [Zabbix Agent] installed successfully  C:\zabbix\bin>zabbix_agentd.exe --start zabbix_agentd.exe [22328]: service [Zabbix Agent] started successfully
    Does anyone knows how can I solve this problem?
    Thank you.
