Zabbix-proxy and data arrival delay ( more than 2 hrs delay)
  • zabbixfk
    • Jun 2013
    • 256
    I am seeing systems which are monitered by zabbix proxy are not updating data, more than 2 hrs of delay to zabbix server.
    zabbix proxy is running on a vm with 4G ram, 4core processor.
    zabbix master is running on 32G ram, with 8core processor.
    Is there anything specific things to be changed, pls advice
    Nodes which are mixture of snmp/zabbix agent items which are monitored by zabbix proxy are close to 270+.
    zabbix_proxy conf
    Server=172.17.1.108
    Hostname=NM-Zabbix-Proxy
    LogFile=/var/log/zabbix/zabbix_proxy.log
    DebugLevel=4
    PidFile=/var/run/zabbix_proxy.pid
    DBName=zabbix
    DBUser=zabbix
    DBPassword=zabbix
    ConfigFrequency=600
    DataSenderFrequency=5
    StartPollers=30
    StartPollersUnreachable=30
    StartTrappers=30
    StartPingers=30
    StartSNMPTrapper=1
    ListenIP=192.168.1.67
    CacheSize=512M
    HistoryCacheSize=512M
    HistoryTextCacheSize=256M
    Timeout=30
    UnreachablePeriod=60
    FpingLocation=/usr/local/sbin/fping
    LogSlowQueries=300000
    zabbix queue
    zabbix server conf
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=50
    DebugLevel=2
    PidFile=/var/run/zabbix/zabbix_server.pid
    DBName=zabbix
    DBUser=zabbix
    DBPassword=zabbix
    StartPollers=45
    StartPollersUnreachable=12
    StartTrappers=45
    StartPingers=45
    StartDiscoverers=3
    StartSNMPTrapper=1
    ListenIP=0.0.0.0
    HousekeepingFrequency=1
    MaxHousekeeperDelete=500
    SenderFrequency=300
    CacheSize=1G
    CacheUpdateFrequency=300
    StartDBSyncers=4
    HistoryCacheSize=128M
    TrendCacheSize=1G
    HistoryTextCacheSize=128M
    Timeout=30
    TrapperTimeout=120
    UnreachablePeriod=600
    UnavailableDelay=120
    AlertScriptsPath=/etc/zabbix/alert.d/
    LogSlowQueries=1
    mysql_conf
    datadir=/var/lib/mysql
    socket=/var/lib/mysql/mysql.sock
    user=mysql
    symbolic-links=0
    slow_query_log_file=/var/log/mysql/slow-query.log
    long_query_time = 10
    log-queries-not-using-indexes=YES
    innodb_lock_wait_timeout=500
    innodb_locks_unsafe_for_binlog=1
    expire_logs_days=5
    max_binlog_size=100M
    innodb_buffer_pool_size=20G
    innodb_file_per_table
    max_allowed_packet = 64M
    innodb_additional_mem_pool_size = 30M
    innodb_thread_concurrency = 8
    key_buffer_size = 60M
    max_connections=290
    table_cache=4096
    query_cache_size = 96M
    tmp_table_size = 32M
    thread_cache_size = 64
    sort_buffer_size = 12M
    query_cache_limit=64M
    thread_cache_size=512
    wait_timeout=300
    read_buffer_size=2M
    read_rnd_buffer_size=8M
    join_buffer_size=8M
    log-bin=/var/log/mysql/mysql-bin.log
    binlog-do-db=zabbix
    server-id=1
    [mysqld_safe]
    log-error=/var/log/mysql/mysqld.log
    pid-file=/var/run/mysqld/mysqld.pid
    zbx_server queue
    ANy pointers are greatly helpful.
  • Pada
    • Apr 2012
    • 236
    What does your Zabbix dashboard say for "Required server performance, new values per second" ?
    I would recommend that you install the Zabbix_Server and Zabbix_Proxy templates, so that you can determine what percentages of the pollers and other Zabbix processes are busy. Unfortunately the Zabbix Proxy monitoring is only available from version 2.2
    If you are monitoring many hosts (or items), then I would highly recommend that you use Zabbix Agent (active) and not the passive ("Zabbix Agent") item. Active items uses a lot less resources on your proxy/server.
    From v2.2.3 the Proxies & Servers can support bulk SNMP requests, where they query multiple SNMP items with a single request. See https://www.zabbix.com/documentation...itemtypes/snmp for more detail.
    You may want to decrease the timeout values, because 30 seconds is an awful lot for the SNMP Timeout.
    If your hosts that make use of SNMP does not return values immediately, then you should have a look at it! Like we had 1 or 2 SNMP items in our setup that would take 3-5 seconds to return, which cause lots of issues for us, because with a timeout of 3 seconds it caused the whole host to go into a unavailable kind of state.
    So we basically got rid of all our passive kind of monitoring items and replaced them with Zabbix Agent (active) or Zabbix Trapper items. Our Zabbix proxy instances are like EC2 Micro instances, and they do roughly 100 hosts / 2000 items (75 new values per second).
    Decreasing the Update Interval an also have a dramatic effect. Like I won't recommended to use anything lower than 30s, unless you have to for only a few items.
    • zabbixfk
      • Jun 2013
      • 256
      [SOLVED] Zabbix-proxy and data arrival delay ( more than 2 hrs delay)
      Thanks for the reply.
      Well, after a couple of weeks of observation, and tweeking ( changed the HDD of server with greater I/O ops, changing item polling intervals etc), now i am able to get values properly.
      Thanks.
