Can't get zabbix to run on Ubuntu 18.04
  • LittleNo
    • Apr 2019
    I wanted to try zabbix and setup two virtual machines (running KVM on a Ubuntu 18.04 host) for testing. For network access the VMs use bridged network interface, so both machines have their own IPs inside my LAN.
    Server: hostname "zabbixvm", IP 192.168.3.85
    Agent: hostname "nextcloudvm", IP 192.168.3.43
    As you can see on the screenshot, my Agent-VM does not show up as available on the server.
    The Agent-logfile on "nextcloudvm" has only a few lines showing nothing that sounds wrong. However, the Server-logfile has hundreds of entries only seconds after a start of the service.
    Since this was a clean install of Ubuntu 18.04 Server and I followed exactly the instructions on the zabbix-download-page, I have no clue what should have gone wrong here. Any ideas?
     30796:20190418:182635.867 Starting Zabbix Server. Zabbix 4.0.7 (revision 92831).
     30796:20190418:182635.867 ****** Enabled features ******
     30796:20190418:182635.867 SNMP monitoring:           YES
     30796:20190418:182635.867 IPMI monitoring:           YES
     30796:20190418:182635.867 Web monitoring:            YES
     30796:20190418:182635.867 VMware monitoring:         YES
     30796:20190418:182635.867 SMTP authentication:       YES
     30796:20190418:182635.867 Jabber notifications:      YES
     30796:20190418:182635.867 Ez Texting notifications:  YES
     30796:20190418:182635.867 ODBC:                      YES
     30796:20190418:182635.867 SSH2 support:              YES
     30796:20190418:182635.867 IPv6 support:              YES
     30796:20190418:182635.867 TLS support:               YES
     30796:20190418:182635.867 ******************************
     30796:20190418:182635.867 using configuration file: /etc/zabbix/zabbix_server.conf
     30796:20190418:182635.873 current database version (mandatory/optional): 04000000/04000003
     30796:20190418:182635.873 required mandatory version: 04000000
     30796:20190418:182635.918 server #0 started [main process]
     30802:20190418:182635.919 server #2 started [housekeeper #1]
     30803:20190418:182635.919 server #3 started [timer #1]
     30804:20190418:182635.919 server #4 started [http poller #1]
     30805:20190418:182635.920 server #5 started [discoverer #1]
     30801:20190418:182635.922 server #1 started [configuration syncer #1]
     30809:20190418:182635.922 server #9 started [history syncer #4]
     30806:20190418:182635.923 server #6 started [history syncer #1]
    MIB search path: $HOME/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
    Cannot find module (SNMPv2-MIB): At line 1 in (none)
    Cannot find module (IF-MIB): At line 1 in (none)
    Cannot find module (IP-MIB): At line 1 in (none)
    Cannot find module (TCP-MIB): At line 1 in (none)
    Cannot find module (UDP-MIB): At line 1 in (none)
    Cannot find module (HOST-RESOURCES-MIB): At line 1 in (none)
    Cannot find module (NOTIFICATION-LOG-MIB): At line 1 in (none)
    Cannot find module (DISMAN-EVENT-MIB): At line 1 in (none)
    Cannot find module (DISMAN-SCHEDULE-MIB): At line 1 in (none)
    Cannot find module (HOST-RESOURCES-TYPES): At line 1 in (none)
    Cannot find module (MTA-MIB): At line 1 in (none)
    Cannot find module (NETWORK-SERVICES-MIB): At line 1 in (none)
    Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
     30808:20190418:182635.926 server #8 started [history syncer #3]
     30807:20190418:182635.927 server #7 started [history syncer #2]
    Cannot find module (SNMPv2-SMI): At line 34 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
    Cannot find module (SNMPv2-TC): At line 37 in /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
    Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
    Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/UCD-SNMP-MIB.txt)
    Unlinked OID in UCD-SNMP-MIB: ucdavis ::= { enterprises 2021 }
    Undefined identifier: enterprises near line 39 of /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
    Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DISKIO-MIB.txt)
    Unlinked OID in UCD-DISKIO-MIB: ucdDiskIOMIB ::= { ucdExperimental 15 }
    Undefined identifier: ucdExperimental near line 19 of /usr/share/snmp/mibs/UCD-DISKIO-MIB.txt
    Cannot find module (SNMPv2-TC): At line 10 in /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
    Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DLMOD-MIB.txt)
    Unlinked OID in UCD-DLMOD-MIB: ucdDlmodMIB ::= { ucdExperimental 14 }
    Undefined identifier: ucdExperimental near line 13 of /usr/share/snmp/mibs/UCD-DLMOD-MIB.txt
    Cannot find module (SNMPv2-TC): At line 15 in /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
    Did not find 'ucdExperimental' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/LM-SENSORS-MIB.txt)
    Unlinked OID in LM-SENSORS-MIB: lmSensors ::= { ucdExperimental 16 }
    Undefined identifier: ucdExperimental near line 32 of /usr/share/snmp/mibs/LM-SENSORS-MIB.txt
    Did not find 'ucdavis' in module UCD-SNMP-MIB (/usr/share/snmp/mibs/UCD-DEMO-MIB.txt)
    Unlinked OID in UCD-DEMO-MIB: ucdDemoMIB ::= { ucdavis 14 }
    Undefined identifier: ucdavis near line 7 of /usr/share/snmp/mibs/UCD-DEMO-MIB.txt
    Cannot find module (SNMP-TARGET-MIB): At line 1 in (none)
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Cannot find module (SNMPv2-SMI): At line 8 in /usr/share/snmp/mibs/NET-SNMP-MIB.txt
    Did not find 'enterprises' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-MIB.txt)
    Unlinked OID in NET-SNMP-MIB: netSnmp ::= { enterprises 8072 }
    Undefined identifier: enterprises near line 10 of /usr/share/snmp/mibs/NET-SNMP-MIB.txt
    Cannot find module (SNMPv2-TC): At line 21 in /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'netSnmpModuleIDs' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'netSnmpNotifications' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Did not find 'TruthValue' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt)
    Unlinked OID in NET-SNMP-AGENT-MIB: nsAgentNotifyGroup ::= { netSnmpGroups 9 }
    Undefined identifier: netSnmpGroups near line 545 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactionGroup ::= { netSnmpGroups 8 }
    Undefined identifier: netSnmpGroups near line 536 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsConfigGroups ::= { netSnmpGroups 7 }
    Undefined identifier: netSnmpGroups near line 515 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
    Undefined identifier: netSnmpGroups near line 505 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
    Undefined identifier: netSnmpGroups near line 495 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: netSnmpAgentMIB ::= { netSnmpModuleIDs 2 }
    Undefined identifier: netSnmpModuleIDs near line 24 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsTransactions ::= { netSnmpObjects 8 }
    Undefined identifier: netSnmpObjects near line 55 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsConfiguration ::= { netSnmpObjects 7 }
    Undefined identifier: netSnmpObjects near line 54 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsErrorHistory ::= { netSnmpObjects 6 }
    Undefined identifier: netSnmpObjects near line 53 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsCache ::= { netSnmpObjects 5 }
    Undefined identifier: netSnmpObjects near line 52 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsDLMod ::= { netSnmpObjects 4 }
    Undefined identifier: netSnmpObjects near line 51 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsExtensions ::= { netSnmpObjects 3 }
    Undefined identifier: netSnmpObjects near line 50 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsMibRegistry ::= { netSnmpObjects 2 }
    Undefined identifier: netSnmpObjects near line 49 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsVersion ::= { netSnmpObjects 1 }
    Undefined identifier: netSnmpObjects near line 48 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
    Undefined identifier: netSnmpNotifications near line 482 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
    Undefined identifier: netSnmpNotifications near line 476 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Unlinked OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
    Undefined identifier: netSnmpNotifications near line 470 of /usr/share/snmp/mibs/NET-SNMP-AGENT-MIB.txt
    Cannot find module (SNMP-MPD-MIB): At line 1 in (none)
    Cannot find module (SNMP-USER-BASED-SM-MIB): At line 1 in (none)
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 1 in (none)
    Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 1 in (none)
    Cannot find module (SNMP-COMMUNITY-MIB): At line 1 in (none)
    Cannot find module (IPV6-ICMP-MIB): At line 1 in (none)
    Cannot find module (IPV6-MIB): At line 1 in (none)
    Cannot find module (IPV6-TCP-MIB): At line 1 in (none)
    Cannot find module (IPV6-UDP-MIB): At line 1 in (none)
    Cannot find module (IP-FORWARD-MIB): At line 1 in (none)
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 10 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
    Cannot find module (SNMPv2-TC): At line 12 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
    Cannot find module (INET-ADDRESS-MIB): At line 13 in /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
    Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Did not find 'netSnmp' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Did not find 'InetAddressType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Did not find 'InetAddress' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt)
    Unlinked OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
    Undefined identifier: netSnmp near line 16 of /usr/share/snmp/mibs/NET-SNMP-EXAMPLES-MIB.txt
    Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
    Did not find 'netSnmpExamples' in module NET-SNMP-EXAMPLES-MIB (/usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt)
    Unlinked OID in NET-SNMP-PASS-MIB: netSnmpPassExamples ::= { netSnmpExamples 255 }
    Undefined identifier: netSnmpExamples near line 14 of /usr/share/snmp/mibs/NET-SNMP-PASS-MIB.txt
    Cannot find module (SNMPv2-TC): At line 16 in /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
    Did not find 'nsExtensions' in module NET-SNMP-AGENT-MIB (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
    Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
    Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt)
    Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendGroups ::= { nsExtensions 3 }
    Undefined identifier: nsExtensions near line 39 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
    Unlinked OID in NET-SNMP-EXTEND-MIB: nsExtendObjects ::= { nsExtensions 2 }
    Undefined identifier: nsExtensions near line 38 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
    Unlinked OID in NET-SNMP-EXTEND-MIB: netSnmpExtendMIB ::= { nsExtensions 1 }
    Undefined identifier: nsExtensions near line 19 of /usr/share/snmp/mibs/NET-SNMP-EXTEND-MIB.txt
    Cannot find module (SNMP-NOTIFICATION-MIB): At line 1 in (none)
    Cannot find module (SNMPv2-TM): At line 1 in (none)
    Cannot find module (SNMP-FRAMEWORK-MIB): At line 9 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
    Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 16 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
    Cannot find module (SNMPv2-TC): At line 25 in /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
    Did not find 'SnmpAdminString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'netSnmpObjects' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'netSnmpGroups' in module NET-SNMP-MIB (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'vacmGroupName' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'vacmAccessContextPrefix' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'vacmAccessSecurityModel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'vacmAccessSecurityLevel' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'DisplayString' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'RowStatus' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Did not find 'StorageType' in module #-1 (/usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt)
    Unlinked OID in NET-SNMP-VACM-MIB: netSnmpVacmMIB ::= { netSnmpObjects 9 }
    Undefined identifier: netSnmpObjects near line 28 of /usr/share/snmp/mibs/NET-SNMP-VACM-MIB.txt
    Cannot adopt OID in UCD-SNMP-MIB: logMatchRegExCompilation ::= { logMatchEntry 101 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchErrorFlag ::= { logMatchEntry 100 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchCycle ::= { logMatchEntry 11 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchCount ::= { logMatchEntry 10 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchCounter ::= { logMatchEntry 9 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCount ::= { logMatchEntry 8 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchCurrentCounter ::= { logMatchEntry 7 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCount ::= { logMatchEntry 6 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchGlobalCounter ::= { logMatchEntry 5 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchRegEx ::= { logMatchEntry 4 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchFilename ::= { logMatchEntry 3 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchName ::= { logMatchEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: logMatchIndex ::= { logMatchEntry 1 }
    Cannot adopt OID in NET-SNMP-VACM-MIB: nsVacmAccessEntry ::= { nsVacmAccessTable 1 }
    Cannot adopt OID in UCD-SNMP-MIB: extErrFixCmd ::= { extEntry 103 }
    Cannot adopt OID in UCD-SNMP-MIB: extErrFix ::= { extEntry 102 }
    Cannot adopt OID in UCD-SNMP-MIB: extOutput ::= { extEntry 101 }
    Cannot adopt OID in UCD-SNMP-MIB: extResult ::= { extEntry 100 }
    Cannot adopt OID in UCD-SNMP-MIB: extCommand ::= { extEntry 3 }
    Cannot adopt OID in UCD-SNMP-MIB: extNames ::= { extEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: extIndex ::= { extEntry 1 }
    Cannot adopt OID in UCD-DEMO-MIB: ucdDemoPublic ::= { ucdDemoMIBObjects 1 }
    Cannot adopt OID in UCD-DLMOD-MIB: dlmodTable ::= { ucdDlmodMIB 2 }
    Cannot adopt OID in UCD-DLMOD-MIB: dlmodNextIndex ::= { ucdDlmodMIB 1 }
    Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExamples ::= { netSnmp 2 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpConformance ::= { netSnmp 5 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationPrefix ::= { netSnmp 4 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpExperimental ::= { netSnmp 9999 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpEnumerations ::= { netSnmp 3 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpObjects ::= { netSnmp 1 }
    Cannot adopt OID in UCD-SNMP-MIB: versionDoDebugging ::= { version 20 }
    Cannot adopt OID in UCD-SNMP-MIB: versionSavePersistentData ::= { version 13 }
    Cannot adopt OID in UCD-SNMP-MIB: versionRestartAgent ::= { version 12 }
    Cannot adopt OID in UCD-SNMP-MIB: versionUpdateConfig ::= { version 11 }
    Cannot adopt OID in UCD-SNMP-MIB: versionClearCache ::= { version 10 }
    Cannot adopt OID in UCD-SNMP-MIB: versionConfigureOptions ::= { version 6 }
    Cannot adopt OID in UCD-SNMP-MIB: versionIdent ::= { version 5 }
    Cannot adopt OID in UCD-SNMP-MIB: versionCDate ::= { version 4 }
    Cannot adopt OID in UCD-SNMP-MIB: versionDate ::= { version 3 }
    Cannot adopt OID in UCD-SNMP-MIB: versionTag ::= { version 2 }
    Cannot adopt OID in UCD-SNMP-MIB: versionIndex ::= { version 1 }
    Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpExampleHeartbeatNotification ::= { netSnmpExampleNotificationPrefix 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheStatus ::= { nsCacheEntry 3 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheTimeout ::= { nsCacheEntry 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCachedOID ::= { nsCacheEntry 1 }
    Cannot adopt OID in UCD-SNMP-MIB: unknown ::= { ucdSnmpAgent 255 }
    Cannot adopt OID in UCD-SNMP-MIB: dragonfly ::= { ucdSnmpAgent 17 }
    Cannot adopt OID in UCD-SNMP-MIB: macosx ::= { ucdSnmpAgent 16 }
    Cannot adopt OID in UCD-SNMP-MIB: aix ::= { ucdSnmpAgent 15 }
    Cannot adopt OID in UCD-SNMP-MIB: hpux11 ::= { ucdSnmpAgent 14 }
    Cannot adopt OID in UCD-SNMP-MIB: win32 ::= { ucdSnmpAgent 13 }
    Cannot adopt OID in UCD-SNMP-MIB: openbsd ::= { ucdSnmpAgent 12 }
    Cannot adopt OID in UCD-SNMP-MIB: bsdi ::= { ucdSnmpAgent 11 }
    Cannot adopt OID in UCD-SNMP-MIB: linux ::= { ucdSnmpAgent 10 }
    Cannot adopt OID in UCD-SNMP-MIB: irix ::= { ucdSnmpAgent 9 }
    Cannot adopt OID in UCD-SNMP-MIB: freebsd ::= { ucdSnmpAgent 8 }
    Cannot adopt OID in UCD-SNMP-MIB: netbsd1 ::= { ucdSnmpAgent 7 }
    Cannot adopt OID in UCD-SNMP-MIB: hpux10 ::= { ucdSnmpAgent 6 }
    Cannot adopt OID in UCD-SNMP-MIB: ultrix ::= { ucdSnmpAgent 5 }
    Cannot adopt OID in UCD-SNMP-MIB: osf ::= { ucdSnmpAgent 4 }
    Cannot adopt OID in UCD-SNMP-MIB: solaris ::= { ucdSnmpAgent 3 }
    Cannot adopt OID in UCD-SNMP-MIB: sunos4 ::= { ucdSnmpAgent 2 }
    Cannot adopt OID in UCD-SNMP-MIB: hpux9 ::= { ucdSnmpAgent 1 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputGroup ::= { nsExtendGroups 2 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendConfigGroup ::= { nsExtendGroups 1 }
    Cannot adopt OID in UCD-DISKIO-MIB: diskIOEntry ::= { diskIOTable 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionEntry ::= { nsTransactionTable 1 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpGroups ::= { netSnmpConformance 2 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpCompliances ::= { netSnmpConformance 1 }
    Cannot adopt OID in UCD-SNMP-MIB: mrModuleName ::= { mrEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: mrIndex ::= { mrEntry 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugTokenEntry ::= { nsDebugTokenTable 1 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStatus ::= { nsExtendConfigEntry 21 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendStorage ::= { nsExtendConfigEntry 20 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendRunType ::= { nsExtendConfigEntry 7 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendExecType ::= { nsExtendConfigEntry 6 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCacheTime ::= { nsExtendConfigEntry 5 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendInput ::= { nsExtendConfigEntry 4 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendArgs ::= { nsExtendConfigEntry 3 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendCommand ::= { nsExtendConfigEntry 2 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendToken ::= { nsExtendConfigEntry 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTable ::= { nsMibRegistry 1 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpPlaypen ::= { netSnmpExperimental 9999 }
    Cannot adopt OID in NET-SNMP-EXAMPLES-MIB: netSnmpIETFWGEntry ::= { netSnmpIETFWGTable 1 }
    Cannot adopt OID in UCD-SNMP-MIB: prErrFixCmd ::= { prEntry 103 }
    Cannot adopt OID in UCD-SNMP-MIB: prErrFix ::= { prEntry 102 }
    Cannot adopt OID in UCD-SNMP-MIB: prErrMessage ::= { prEntry 101 }
    Cannot adopt OID in UCD-SNMP-MIB: prErrorFlag ::= { prEntry 100 }
    Cannot adopt OID in UCD-SNMP-MIB: prCount ::= { prEntry 5 }
    Cannot adopt OID in UCD-SNMP-MIB: prMax ::= { prEntry 4 }
    Cannot adopt OID in UCD-SNMP-MIB: prMin ::= { prEntry 3 }
    Cannot adopt OID in UCD-SNMP-MIB: prNames ::= { prEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: prIndex ::= { prEntry 1 }
    Cannot adopt OID in UCD-DLMOD-MIB: dlmodEntry ::= { dlmodTable 1 }
    Cannot adopt OID in UCD-SNMP-MIB: memSwapErrorMsg ::= { memory 101 }
    Cannot adopt OID in UCD-SNMP-MIB: memSwapError ::= { memory 100 }
    Cannot adopt OID in UCD-SNMP-MIB: memUsedRealTXT ::= { memory 17 }
    Cannot adopt OID in UCD-SNMP-MIB: memUsedSwapTXT ::= { memory 16 }
    Cannot adopt OID in UCD-SNMP-MIB: memCached ::= { memory 15 }
    Cannot adopt OID in UCD-SNMP-MIB: memBuffer ::= { memory 14 }
    Cannot adopt OID in UCD-SNMP-MIB: memShared ::= { memory 13 }
    Cannot adopt OID in UCD-SNMP-MIB: memMinimumSwap ::= { memory 12 }
    Cannot adopt OID in UCD-SNMP-MIB: memTotalFree ::= { memory 11 }
    Cannot adopt OID in UCD-SNMP-MIB: memAvailRealTXT ::= { memory 10 }
    Cannot adopt OID in UCD-SNMP-MIB: memTotalRealTXT ::= { memory 9 }
    Cannot adopt OID in UCD-SNMP-MIB: memAvailSwapTXT ::= { memory 8 }
    Cannot adopt OID in UCD-SNMP-MIB: memTotalSwapTXT ::= { memory 7 }
    Cannot adopt OID in UCD-SNMP-MIB: memAvailReal ::= { memory 6 }
    Cannot adopt OID in UCD-SNMP-MIB: memTotalReal ::= { memory 5 }
    Cannot adopt OID in UCD-SNMP-MIB: memAvailSwap ::= { memory 4 }
    Cannot adopt OID in UCD-SNMP-MIB: memTotalSwap ::= { memory 3 }
    Cannot adopt OID in UCD-SNMP-MIB: memErrorName ::= { memory 2 }
    Cannot adopt OID in UCD-SNMP-MIB: memIndex ::= { memory 1 }
    Cannot adopt OID in UCD-DEMO-MIB: ucdDemoMIBObjects ::= { ucdDemoMIB 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleTimeout ::= { nsModuleEntry 6 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleModes ::= { nsModuleEntry 5 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleName ::= { nsModuleEntry 4 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPriority ::= { nsModuleEntry 3 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmRegistrationPoint ::= { nsModuleEntry 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsmContextName ::= { nsModuleEntry 1 }
    Cannot adopt OID in LM-SENSORS-MIB: lmMiscSensorsEntry ::= { lmMiscSensorsTable 1 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpNotificationObjects ::= { netSnmpNotificationPrefix 1 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpNotifications ::= { netSnmpNotificationPrefix 0 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTable ::= { netSnmpPassExamples 2 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassOIDValue ::= { netSnmpPassExamples 99 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassGauge ::= { netSnmpPassExamples 6 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassCounter ::= { netSnmpPassExamples 5 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassIpAddress ::= { netSnmpPassExamples 4 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassTimeTicks ::= { netSnmpPassExamples 3 }
    Cannot adopt OID in NET-SNMP-PASS-MIB: netSnmpPassString ::= { netSnmpPassExamples 1 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpDomains ::= { netSnmpEnumerations 3 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpAgentOIDs ::= { netSnmpEnumerations 2 }
    Cannot adopt OID in NET-SNMP-MIB: netSnmpModuleIDs ::= { netSnmpEnumerations 1 }
    Cannot adopt OID in LM-SENSORS-MIB: lmFanSensorsEntry ::= { lmFanSensorsTable 1 }
    Cannot adopt OID in LM-SENSORS-MIB: lmTempSensorsEntry ::= { lmTempSensorsTable 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsModuleGroup ::= { netSnmpGroups 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsCacheGroup ::= { netSnmpGroups 4 }
    ...removed content due to character limitation of the forum...
    Cannot adopt OID in UCD-SNMP-MIB: dskErrorFlag ::= { dskEntry 100 }
    Cannot adopt OID in UCD-SNMP-MIB: dskUsedHigh ::= { dskEntry 16 }
    Cannot adopt OID in UCD-SNMP-MIB: dskUsedLow ::= { dskEntry 15 }
    Cannot adopt OID in UCD-SNMP-MIB: dskAvailHigh ::= { dskEntry 14 }
    Cannot adopt OID in UCD-SNMP-MIB: dskAvailLow ::= { dskEntry 13 }
    Cannot adopt OID in UCD-SNMP-MIB: dskTotalHigh ::= { dskEntry 12 }
    Cannot adopt OID in UCD-SNMP-MIB: dskTotalLow ::= { dskEntry 11 }
    Cannot adopt OID in UCD-SNMP-MIB: dskPercentNode ::= { dskEntry 10 }
    Cannot adopt OID in UCD-SNMP-MIB: dskPercent ::= { dskEntry 9 }
    Cannot adopt OID in UCD-SNMP-MIB: dskUsed ::= { dskEntry 8 }
    Cannot adopt OID in UCD-SNMP-MIB: dskAvail ::= { dskEntry 7 }
    Cannot adopt OID in UCD-SNMP-MIB: dskTotal ::= { dskEntry 6 }
    Cannot adopt OID in UCD-SNMP-MIB: dskMinPercent ::= { dskEntry 5 }
    Cannot adopt OID in UCD-SNMP-MIB: dskMinimum ::= { dskEntry 4 }
    Cannot adopt OID in UCD-SNMP-MIB: dskDevice ::= { dskEntry 3 }
    Cannot adopt OID in UCD-SNMP-MIB: dskPath ::= { dskEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: dskIndex ::= { dskEntry 1 }
    Cannot adopt OID in UCD-DISKIO-MIB: diskIOTable ::= { ucdDiskIOMIB 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLoggingGroup ::= { nsConfigGroups 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsDebugGroup ::= { nsConfigGroups 1 }
    Cannot adopt OID in UCD-SNMP-MIB: snmperrErrMessage ::= { snmperrs 101 }
    Cannot adopt OID in UCD-SNMP-MIB: snmperrErrorFlag ::= { snmperrs 100 }
    Cannot adopt OID in UCD-SNMP-MIB: snmperrNames ::= { snmperrs 2 }
    Cannot adopt OID in UCD-SNMP-MIB: snmperrIndex ::= { snmperrs 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsTransactionTable ::= { nsTransactions 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogStatus ::= { nsLoggingEntry 5 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogMaxLevel ::= { nsLoggingEntry 4 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogType ::= { nsLoggingEntry 3 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogToken ::= { nsLoggingEntry 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsLogLevel ::= { nsLoggingEntry 1 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendResult ::= { nsExtendOutput1Entry 4 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutNumLines ::= { nsExtendOutput1Entry 3 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutputFull ::= { nsExtendOutput1Entry 2 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutput1Line ::= { nsExtendOutput1Entry 1 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendOutLine ::= { nsExtendOutput2Entry 2 }
    Cannot adopt OID in NET-SNMP-EXTEND-MIB: nsExtendLineIndex ::= { nsExtendOutput2Entry 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyStart ::= { netSnmpNotifications 1 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyShutdown ::= { netSnmpNotifications 2 }
    Cannot adopt OID in NET-SNMP-AGENT-MIB: nsNotifyRestart ::= { netSnmpNotifications 3 }
    Cannot adopt OID in UCD-SNMP-MIB: laErrMessage ::= { laEntry 101 }
    Cannot adopt OID in UCD-SNMP-MIB: laErrorFlag ::= { laEntry 100 }
    Cannot adopt OID in UCD-SNMP-MIB: laLoadFloat ::= { laEntry 6 }
    Cannot adopt OID in UCD-SNMP-MIB: laLoadInt ::= { laEntry 5 }
    Cannot adopt OID in UCD-SNMP-MIB: laConfig ::= { laEntry 4 }
    Cannot adopt OID in UCD-SNMP-MIB: laLoad ::= { laEntry 3 }
    Cannot adopt OID in UCD-SNMP-MIB: laNames ::= { laEntry 2 }
    Cannot adopt OID in UCD-SNMP-MIB: laIndex ::= { laEntry 1 }
     30840:20190418:182636.023 server #25 started [icmp pinger #1]
     30869:20190418:182636.025 server #33 started [preprocessing worker #3]
     30868:20190418:182636.028 server #32 started [preprocessing worker #2]
     30822:20190418:182636.037 enabling Zabbix agent checks on host "Zabbix server": host became available
     30807:20190418:182641.957 item "Zabbix server:zabbix[process,ipmi poller,avg,busy]" became not supported: No "ipmi poller" processes started.
     30806:20190418:182642.958 item "Zabbix server:zabbix[process,java poller,avg,busy]" became not supported: No "java poller" processes started.
     30828:20190418:182646.917 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30806:20190418:182647.979 item "Zabbix server:zabbix[process,ipmi manager,avg,busy]" became not supported: No "ipmi manager" processes started.
     30806:20190418:182647.979 item "Zabbix server:zabbix[process,snmp trapper,avg,busy]" became not supported: No "snmp trapper" processes started.
     30808:20190418:182648.980 item "Zabbix server:zabbix[process,vmware collector,avg,busy]" became not supported: No "vmware collector" processes started.
     30809:20190418:182655.053 item "Zabbix server:zabbix[vmware,buffer,pused]" became not supported: No "vmware collector" processes started.
     30825:20190418:182847.460 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30829:20190418:183047.974 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30827:20190418:183247.514 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30827:20190418:183448.143 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30826:20190418:183535.069 cannot send list of active checks to "127.0.0.1": host [Zabbix server] not found
     30827:20190418:183647.705 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30828:20190418:183735.095 cannot send list of active checks to "127.0.0.1": host [Zabbix server] not found
     30829:20190418:183848.229 cannot send list of active checks to "192.168.3.84": host [WIN10VM] not found
     30829:20190418:183935.122 cannot send list of active checks to "127.0.0.1": host [Zabbix server] not found
  • Atsushi
    • Aug 2013
    • 2028
    Link something with the template or set something to monitoring item for the host 'nextcloudvm'. If there are no monitoring items set, the status of the icons in the Availability column does not change.
    After that, you can prevent the output of unnecessary Zabbix server logs by installing the snmp package.
    • LittleNo
      • Apr 2019
      thanks, got it to work
