zabbix4.2 [Z3005] query failed
  • marksugar
    • Apr 2019
    I encountered a problem when using zabbix4.2, I tried to modify it several times and did not solve the problem.
    I am using docker-compose orchestration and using elasticsearch
    Configuration information:
    mariadb:10.2.15
    elasticsearch:5.6.16-alpine
    zabbix/zabbix-server-mysql:alpine-4.2-latest
    zabbix/zabbix-web-nginx-mysql:alpine-4.2-latest
    - zabbix-web-nginx-mysql
    environment:
    - DB_SERVER_HOST=127.0.0.1
    - MYSQL_DATABASE=zabbix
    - MYSQL_USER=zabbix
    - MYSQL_PASSWORD=password
    - ZBX_SERVER_HOST=127.0.0.1
    - ZBX_HISTORYSTORAGEURL=http://127.0.0.1:9200
    # - ZBX_HISTORYSTORAGETYPES=['str', 'text', 'log'] # uint,dbl,str,log,text
    - ZBX_HISTORYSTORAGETYPES=['dbl','uint','str', 'text', 'log'] # uint,dbl,str,log,text
    - zabbix/zabbix-server-mysql:alpine-4.2-latest
    environment:
    - MYSQL_USER=zabbix
    - MYSQL_ROOT_PASSWORD=abc123
    - ZBX_HISTORYSTORAGEURL=http://127.0.0.1:9200 # elasticsearch
    - ZBX_HISTORYSTORAGETYPES=uint,dbl,str,log,text # stor add elasticsearch type
    # zabbix_server configure
    - ZBX_CACHESIZE=1024M
    - ZBX_CACHEUPDATEFREQUENCY=60
    - ZBX_STARTDBSYNCERS=4
    - ZBX_HISTORYCACHESIZE=1024M
    - ZBX_HISTORYINDEXCACHESIZE=512M
    - ZBX_TRENDCACHESIZE=2046M
    - ZBX_VALUECACHESIZE=2048M
    - ZBX_TRAPPERTIMEOUT=30
    - ZBX_UNREACHABLEPERIOD=120
    - ZBX_UNAVAILABLEDELAY=80
    - ZBX_STARTTRAPPERS=50
    - ZBX_STARTPOLLERS=50
    - ZBX_STARTPOLLERSUNREACHABLE=50
    - ZBX_STARTPINGERS=10
    - ZBX_STARTDISCOVERERS=10
    - ZBX_STARTHTTPPOLLERS=1
    - mariadb conf
    [client]
    port = 3306
    socket = /run/mysqld/mysqld.sock
    [mysqld]
    relay_log = relay-bin
    datadir = /data/mariadb
    pid-file = /data/mariadb/mysql.pid
    user = mysql
    bind-address = 0.0.0.0
    server-id = 1
    init-connect = 'SET NAMES utf8'
    character-set-server = utf8
    skip-name-resolve
    back_log = 300
    max_connections = 3993
    max_connect_errors = 1024000
    open_files_limit = 65535
    table_open_cache = 2048
    max_allowed_packet = 4M
    max_heap_table_size = 16M
    tmp_table_size = 256M
    read_buffer_size = 2M
    read_rnd_buffer_size = 16M
    sort_buffer_size = 8M
    join_buffer_size = 8M
    key_buffer_size = 512M
    thread_cache_size = 128
    query_cache_type = 2
    query_cache_size = 128M
    query_cache_limit = 5M
    thread_stack = 192k
    ft_min_word_len = 4
    log_bin = mysql-bin
    binlog_format = ROW
    expire_logs_days = 7
    log_error = /data/mariadb/mysql-error.log
    slow_query_log = 1
    long_query_time = 1
    log_slow_verbosity=query_plan
    slow_query_log_file = /data/mariadb/mysql-slow.log
    performance_schema = 0
    skip-external-locking
    bulk_insert_buffer_size = 4M
    myisam_sort_buffer_size = 32M
    myisam_max_sort_file_size = 128M
    myisam_repair_threads = 1
    default_storage_engine = InnoDB
    innodb_file_per_table = 1
    innodb_open_files = 500
    innodb_buffer_pool_size = 256M
    innodb_write_io_threads = 4
    innodb_read_io_threads = 4
    innodb_thread_concurrency = 0
    innodb_purge_threads = 1
    innodb_flush_log_at_trx_commit = 1
    innodb_log_buffer_size = 2M
    innodb_log_file_size = 16M
    innodb_log_files_in_group = 3
    innodb_max_dirty_pages_pct = 90
    innodb_lock_wait_timeout = 30
    innodb_autoinc_lock_mode = 2
    innodb_doublewrite = 1
    innodb_rollback_on_timeout = 1
    innodb_force_recovery=0
    innodb_locks_unsafe_for_binlog = 1
    interactive_timeout = 28800
    wait_timeout = 120
    [mysqldump]
    quick
    max_allowed_packet = 16M
    [myisamchk]
    key_buffer_size = 20M
    sort_buffer_size = 20M
    read_buffer = 2M
    write_buffer = 2M
    [mysqlhotcopy]
    interactive-timeout
    mysql-error.log
    2019-04-19 15:20:56 140057019730664 [Warning] Aborted connection 519 to db: 'zabbix' user: 'zabbix' host: '127.0.0.1' (Got timeout reading communication packets)
    Creating users and libraries seems normal
    * DB_SERVER_HOST: 127.0.0.1
    * DB_SERVER_PORT: 3306
    * DB_SERVER_DBNAME: zabbix
    * DB_SERVER_ROOT_USER: root
    * DB_SERVER_ROOT_PASS: abc123
    * DB_SERVER_ZBX_USER: zabbix
    * DB_SERVER_ZBX_PASS: password
    **** MySQL server is not available. Waiting 5 seconds...
    ** Creating 'zabbix' user in MySQL database
    ** Database 'zabbix' does not exist. Creating...
    ** Creating 'zabbix' schema in MySQL
    ** Preparing Zabbix server configuration file
    ** Updating '/etc/zabbix/zabbix_server.conf' para
    error
    1:20190419:150614.255 using configuration file: /etc/zabbix/zabbix_server.conf
    1:20190419:150614.265 current database version (mandatory/optional): 04020000/04020000
    1:20190419:150614.265 required mandatory version: 04020000
    1:20190419:150614.283 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    error
    194:20190419:150714.312 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    194:20190419:150814.335 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    194:20190419:150914.357 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    194:20190419:151014.382 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    194:20190419:151114.408 [Z3005] query failed: [1036] Table '/var/tmp/#sql_168_0.MAI' is read only [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and h.proxy_hostid is null and h.status in (0,1) and i.flags<>2 order by pp.itemid]
    web : monitoring ->overview
    mysqli_query(): (HY000/1036): Table '/var/tmp/#sql_168_0.MAI' is read only [overview.php:208 → getTriggersOverviewData() → getTriggersWithActualSeverity() → CApiWrapper->__call() → CFrontendApiWrapper->callMethod() → CApiWrapper->callMethod() → CFrontendApiWrapper->callClientMethod() → CLocalApiClient->callMethod() → CTrigger->get() → CApiService->customFetch() → DBselect() → mysqli_query() in include/db.inc.php:364]
    Error in query [SELECT DISTINCT t.triggerid,t.expression,t.description,t.value,t.p riority,t.lastchange,t.flags,t.comments FROM triggers t,functions f,items i WHERE i.hostid='10084' AND f.triggerid=t.triggerid AND f.itemid=i.itemid AND NOT EXISTS (SELECT NULL FROM functions f,items i,hosts h WHERE t.triggerid=f.triggerid AND f.itemid=i.itemid AND i.hostid=h.hostid AND (i.status<>0 OR h.status<>0)) AND t.status=0 AND t.flags IN ('0','4') AND ((t.value=1) OR ((t.value=0) AND (t.lastchange>1555657927))) ORDER BY t.description] [Table '/var/tmp/#sql_168_0.MAI' is read only]
    thanks
