JMX key format for <object name>
  • dzv4h7
    • Mar 2014
    I'm having a problem with the definition of a JMX key, probably containing characters that should be escaped by using the backslash.
    The object name contains somewhere double quotes which I, according to the documentation, already escaped.
    However, it looks like it still contains some stuff that results in the status "Unsupported".
    Here the key I need to apply (names are adapted):
    jmx["org.apache.camel:context=aaa-bb-1-ccc.ddd/217-camelGrbContext,type=routes,name=\"Gdi_agiv_GRB_te gel-route\"","InflightExchanges"]
    thnx in advance
    Edit:
    Found my own (stupid) error. I forgot the double quote in the beginning of the object-name.
  • Tec_Technician
    • Dec 2015
    • 39
    Your example really help me!! Thank you very much!!!
    I had the same error, JMX items with double quotes in ObjectName that get Not supported.
    But thanks to your example with the double quotes \"item\"" i fix them all.
    Thanks again.
