Frontend issue
  • king_bongo
    • Jul 2006
    Frontend issue
    I have finally got the Zabbix server starting up and I am now trying to get the front end running. I have copied the PHP files to a directory wher e my Apache2 server can reach them /var/www/zabbix/
    I try to browse to the site and get the following error:
    Fatal error: Call to undefined function: mysql_pconnect() in var/www/zabbix/include/db.inc.php on line 38
    line 38 is:
    $DB=mysql_pconnect($DB_SERVER,$DB_USER,$DB_PASSWOR D);
    I searched the forum and found a post that suggested I check the PHP.ini file.
    I have just checked the PHP.ini file and I dont see anything wrong. I am a complete newb to Linux so I may have missed something.
    <?php
    // DATABASE CONFIGURATION
    // $DB_TYPE ="ORACLE";
    // $DB_TYPE ="POSTGRESQL";
    $DB_TYPE ="MYSQL";
    $DB_SERVER ="localhost";
    $DB_DATABASE ="zabbix";
    $DB_USER ="zabbix";
    $DB_PASSWORD ="zabbix";
    // END OF DATABASE CONFIGURATION
    global $USER_DETAILS;
    if($DB_TYPE == "MYSQL")
    $DB=mysql_connect($DB_SERVER,$DB_USER,$DB_PASSWORD );
    if(!mysql_select_db($DB_DATABASE))
    echo "Error connecting to database [".mysql_error()."]";
    exit;
  • king_bongo
    • Jul 2006
    OK got it working - with the help of howtoforge.com
    vi /etc/apache/httpd.conf
    Make this work:
    <Directory /home/*/public_html> AllowOverride FileInfo AuthConfig Limit Indexes Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec <Limit GET POST OPTIONS PROPFIND> Order allow,deny Allow from all </Limit> <LimitExcept GET POST OPTIONS PROPFIND> Order deny,allow Deny from all </LimitExcept></Directory>
    /etc/init.d/apache restart
    And it started the Frontend, I can see it reporting the Zabbix server as Down so Im off to investigate this issue now......groan...... I just wanna get to play with this thing now
