My current installed packages on the Zabbix main server:
Pretty web page says 2.2.3
I need to install an agent on a server. I downloaded
from the website via links in the docs. Install failed due to missing release file. (Why does the agent need a release file?)
I can't find the 2.2.3-release file anywhere on repo.zabbix.com. Where can I get it?
Do I need a different version of the release file?
Thanks in advance for your help
Dave
[root@tstmon01 ~]# yum list installed | grep zabbix fping.x86_64 2.4b2-16.el6 @zabbix-non-supported libssh2.x86_64 1.4.2-2.el6 @zabbix-non-supported zabbix.x86_64 2.2.3-1.el6 @zabbix zabbix-agent.x86_64 2.2.3-1.el6 @zabbix zabbix-release.noarch 2.2-1.el6 installed zabbix-server.x86_64 2.2.3-1.el6 @zabbix zabbix-server-mysql.x86_64 2.2.3-1.el6 @zabbix zabbix-web.noarch 2.2.3-1.el6 @zabbix zabbix-web-mysql.noarch 2.2.3-1.el6 @zabbix
zabbix-agent-2.2.3-1.el6.x86_64.rpm
[root@tstoradb01 zabbix]# rpm -ivh zabbix-agent-2.2.3-1.el6.x86_64.rpm warning: zabbix-agent-2.2.3-1.el6.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 79ea5ed4: NOKEY error: Failed dependencies: zabbix = 2.2.3-1.el6 is needed by zabbix-agent-2.2.3-1.el6.x86_64 ]
Dave
